/INIBRI/STRA_FGLO
Block Format Keyword Describes the initial strain state for a brick in global reference system.
/INIBRI/STRA_FGLO/unit_ID | |||||||||
brick_ID | Nb_integr | Isolnod | Isolid | nptr | npts | nptt |
For each integration point (Nb_integr > 0)
1 | 2 | 3 | |||||||
12 | 23 | 31 |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
brick_ID | Element
identifier (Integer) |
Nb_integr | Number of integration
points It corresponds to the property definition of this element. (Integer) |
Isolnod | Number of nodes of solid
element (Integer) |
Isolid | Solid elements
formulation It corresponds to the solid elements formulation of in property definition of this element. (Integer) |
nptr | Number of integration
points in direction r. 2 (Integer) |
npts | Number of integration
points in direction s. 2 (Integer) |
nptt | Number of integration
points in direction t. 2 (Integer) |
1 | Strain in direction
1 (Real) |
2 | Strain in direction
2 (Real |
3 | Strain in direction
3 (Real |
12 | Strain in direction
12 (Real |
23 | Strain in direction
23 (Real |
31 | Strain in direction
31 (Real |
- The initial state for brick may be defined by more than one block.
- nptr, npts and nptt are only useful in /PROP/TYPE22 (TSH_COMP).
