/INIVEL
Block Format Keyword Defines initial velocity on a group of nodes.
/INIVEL/type/inivel_ID/unit_ID
inivel_title
VX VY VZ grnd_ID skew_ID
type Initial velocity type.
TRA
Translational material velocity.
ROT
Rotational material velocity.
T+G
Translational and grid material velocity (only used for ALE material).
GRID
Grid material velocity (only used for ALE material).
inivel_ID Initial velocity block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
inivel_title Initial velocity block title.
VX X velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ or [ rad s ]
VY Y velocity.
(Real)
VZ Z velocity.
(Real)
grnd_ID Node group on which specific initial velocities are applied.
(Integer)
skew_ID Skew identifier.
(Integer)
  1. The grnd_ID input is obligatory. The initial velocities will only be applied to nodes belonging to a node group.
  2. Unit of velocity in translation is [ m s ] . In rotation, then angle is in unit [ rad ] and thus the velocity is in unit [ rad s ] .
