/INIVEL/NODE
Block Format Keyword Initialize translational and rotational velocities on each node in the global or in a given coordinate system.
/INIVEL/NODE/inivel_ID/unit_ID
inivel_node_title
node_ID Skew_ID Vxt Vyt Vzt
  Vxr Vyr Vzr
inivel_ID Initial velocity block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
inivel_node_title Initial velocity block title.
node_ID Node identifier on which specified initial velocity is applied.
(Integer)
Skew_ID Skew identifier.
(Integer)
Vxt X component in the local skew of the translational velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Vyt Y component in the local skew of the translational velocity.
(Real)
Vzt Z component in the local skew of the translational velocity.
(Real)
Vxr Rotational velocity in the local skew.
(Real)
[ rad s ]
Vyr Rotational velocity in the local skew.
(Real)
[ rad s ]
Vzr Rotational velocity in the local skew.
(Real)
[ rad s ]
  1. This card can be generated with /STATE/NODE/VEL.
