Output Database
Block Format Keyword Time histories output for different element groups, section output, or gauge output are described in this group.
Groups Keyword Object saved Variables/Descriptions
Time Histories   Global variables IE, KE, TE, TTE, DTE, RKE, CE, HE, EFW, XMOM, YMOM, ZMOM, MASS, DT, SIE, TER, DTE_REL, VX, VY, VZ
/TH/SUBS Subsets IE, KE, XMOM, YMOM, ZMOM, MASS, HE
TURBKE, XCG, YCG, ZCG, XXMOM, YYMOM, ZZMOM
IXX, IYY, IZZ, IXY, IYZ, IZX, RIE, KERB, RKERB, RKE
/TH/PART Parts
/TH/NODE Nodes DX, DY, DZ, VX, VY, VZ, AX, AY, AZ
VRX, VRY, VRZ, ARX, ARY, ARZ, X, Y, Z, TEMP
REACX, REACY, REACZ, REACXX, REACYY, REACZZ
/TH/SHEL 4-node shells F1, F2, F12, Q1, Q2, M1, M2, M12, IEM, IEB, OFF, THIC, EMIN, EMAX, EPSD, E1, E2, E12, SH1, SH2, K1, K2, K12, USRi (i=1,60)
USRII_JJ (II=1,60; JJ=1,99), USRII_JKK (II=1,60; J=1,4; KK=1,99)
SX_JJ, SY_JJ, SXY_JJ, SYZ_JJ, SZX_JJ (JJ=1,99)
/TH/SH3N 3-node shells F1, F2, F12, Q1, Q2, M1, M2, M12, IEM, IEB, OFF, THIC, EMIN, EMAX, EPSD, E1, E2, E12, SH1, SH2, K1, K2, K12, USRi (i=1,60)
/TH/BRIC Solids OFF, SX, SY, SZ, SXY, SYZ, SXZ, LSX, LSY, LSZ, LSXY, LSYZ, LSXZ, IE, DENS, BULK, VOL, PLAS, TEMP, PLSR, DAM1, DAM2, DAM3, DAM4, DAM5, DAMA, SA1, SA2, SA3, CR, CAP, K0, RK, TD, EFIB, ISTA, VPLA, BFRAC, WPLA, SFIB, EPSXX, EPSYY, EPSZZ, EPSXY, EPSXZ, EPSYZ
SXi, SYi, SZi, SXYi, SYZi, SXZi (i=1,8)
LSXi, LSYi, LSZi, LSXYi, LSYZi, LSXZi (i=1,8), USRi (i=1,60)
SXijk, SYijk, SZijk, SXYijk, SYZijk, SXZijk, EPijk (i=1,3; j=1,9; k=1,3)
SXiUk, SYiUk, SZiUk, SXYiUk, SXZiUk, SYZiUk, EPiUk (i=1,3; k=1,3)
SXiDk, SYiDk, SZiDk, SXYiDk, SXZiDk, SYZiDk, EPiDk (i=1,3; k=1,3)
USR1_ijk, USR2_ijk, USR3_ijk, USR4_ijk, USR5_ijk, USR6_ijk, USR7_ijk, USR8_ijk, USR9_ijk (i=1,3; j=1,9; k=1,3)
E11_ik_j, E12_ik_j, E13_ik_j, E22_ik_j, E23_ik_j, E33_ik_j (i=1,3; k=1,3; j=1,200)
S11_ik_j, S12_ik_j, S13_ik_j, S22_ik_j, S23_ik_j, S33_ik_j (i=1,3; k=1,3; j=1,200)
/TH/QUAD 2D quads OFF, SX, SY, SZ, SXY, SYZ, SXZ, IE, DENS, BULK, VOL, PLAS, TEMP, PLSR, DAM1, DAM2, DAM3, DAM4, DAM5, DAMA, SA1, SA2, SA3, CR, CAP, K0, RK, TD, EFIB, ISTA, VPLA, BFRAC, WPLA, SFIB
LSX, LSY, LSZ, LSXY, LSXZ, LSYZ
/TH/BEAM Beams OFF, F1, F2, F3, M1, M2, M3, IE
/TH/TRUSS Trusses OFF, F, IE, A, L, PLAS
/TH/SPRING Springs OFF, FX, FY, FZ, MX, MY, MZ, LX, LY, LZ, RX, RY, RZ, IE, F1, F2
/TH/NSTRAND Multi-strand OFF, FX, LX, IE
/TH/ACCEL Accelerometer AX, AY, AZ, WX, WY, WZ
/TH/SECTIO Section FNX, FNY, FNZ, FTX, FTY, FTZ, M1, M2, M3, WORK, WORKR, FX_error, MX_error, MX, MY, MZ, F1, F2, F3, CX, CY, CZ
/TH/CYL_JO Cylindrical joints FX, FY, FZ, MX, MY, MZ, F, M
/TH/MONVOL Monitored volume
Airbag
MASS, VOL, P, A, T, AO, UO, AC, UC, CP, CV, GAMA
AO1, BO1, UO1, MO1, HO1
AO2, BO2, UO2, MO2, HO2
AO3, BO3, UO3, MO3, HO3
AO4, BO4, UO4, MO4, HO4
AO5, BO5, UO5, MO5, HO5
AO6, BO6, UO6, MO6, HO6
AO7, BO7, UO7, MO7, HO7
AO8, BO8, UO8, MO8, HO8
AO9, BO9, UO9, MO9, HO9
AO10, BO10, UO10, MO10, HO10
/TH/RWALL Rigid wall FNX, FNY, FNZ, FTX, FTY, FTZ
/TH/RBODY Rigid body FX, FY, FZ, MX, MY, MZ, RX, RY, RZ, FXI, FYI, FZI, MXI, MYI, MZI
/TH/FXBODY Flexible body IE, KE, EFW, DE
/TH/GAUGE Gauges P, IE, DENS
/TH/INTER Interface FNX, FNY, FNZ, FTX, FTY, FTZ, SFW (only Interface types 14 and 15)
Following variables are only for interface types 7, 10 and their Sub interfaces (/INTER/SUB):
|FNX|, |FNY|, |FNZ|, ||FN||, |FX|, |FY|, |FZ|, ||F||, MX, MY, MZ
/TH/FRAME Frame OX, OY, OZ, R11, R12, R13, R21, R22, R23, R31, R32, R33
VX, VY, VZ, VRX, VRY, VRZ, AX, AY, AZ, ARX, ARY, ARZ
/TH/MODE Flexible body local modes D, V, A
Time Histories (Part definitions) /THPART/GRBEAM Beam group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRBIC Brick group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRQUAD Quad group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRSH3N 3-node shell group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRSHEL Shell group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRSPRI Spring group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
/THPART/GRTRUS Truss group IE, KE, XMOM, YMOM, ZMOM, MASS, HE
Other Output Databases /ACCEL Node Used to define accelerometers using a node and skew system.
/CLUSTER Brick or spring Used to output force and moment for an assembly of brick or spring elements for post-processing and failure control.
/GAUGE Node or shell Used to define pressure gauge.
/GAUGE/SPH Node or shell Used to define SPH pressure gauge.
/INTER/SUB Node, surface or interface group. Used to output the contact forces for sub-interfaces.
/SECT Brick, shell, truss, spring. Triangle or beam group Used to output force and moment for specific section.
/SECT/CIRCLE Brick, shell, truss, spring. Triangle or beam group. Used to output force and moment for section which are defined with circle.
/SECT/PARAL Brick, shell, truss, spring. Triangle or beam group. Used to output force and moment for section which are defined with parallelogram.
