/INIBRI/DENS
Block Format Keyword Describes the initial state for a brick.
/INIBRI/DENS/unit_ID
brick_ID   value
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
brick_ID Element identifier.
(Integer)
value Date value.
(Real)
  1. The initial state for brick may be defined by more than one block.
