/INIBRI/ENER
Block Format Keyword Describes the initial state for a brick
/INIBRI/ENER/unit_ID
brick_ID   value
unit_ID Unit Identifier.
(Integer, maximum 10 digits)
brick_ID Element identifier.
(Integer)
value Date value.
(Real)
  1. The internal energy is expressed by volume unit.
  2. The initial state for brick may be defined by more than one block.
