/FAIL/EMC
Block Format Keyword Describes failure dependent on effective plastic strain.
/FAIL/EMC/mat_ID/unit_ID
a n b0 c
Card 2
γ ε ˙ 0
Optional Line
fail_ID
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
a Hosford exponent.
Default = 1.0 (Real)
n Stress state sensitivity exponent.
(Real)
b0 Strain to fracture for uni-axial tension. 2
c Friction parameter for triaxiality.
Default = 0.0 (Real)
γ Strain rate sensitivity parameter.
(Real)
ε ˙ 0 Reference strain rate.
Default = 1030 (Real)
[ 1 s ]
fail_ID (Optional) Failure criteria identifier. 3
Example (Metal)
Fracture parameters could be identified with tests like uniaxial tension ( η=1/3,θ=1), pure shear ( η=0,θ=0), and axisymmetric compression ( η=2/3,θ=1).
#RADIOSS STARTER
/UNIT/1
unit for mat
                 Mg                  mm                   s
#-  2. MATERIALS:
/MAT/LAW84/1/1
Swift-voce (metal)
#              RHO_I
                8E-9
#                  E                  NU
             206000.                0.30
#                P12                 P22                 P33               QVOCE               BVOCE
                -0.5                  1.                  3.            524.0000                 25.
#                G11                 G22                 G33                  K0               ALPHA
                -0.5                  1.                  3.                100.                 0.5
#                 AN                EPS0                  NN               CEPSP               DEPS0
               1000.             0.00128               0.200               0.014              0.0011
#                ETA                  CP                TINI                TREF               TMELT
                 0.9              420e+8                 293                293.               1700.
#              MTEMP              DEPSAD
               0.921               1.379
/FAIL/EMC/1/1
#         exponent_a          exponent_n              coef_b              coef_c
                 1.9                 0.2                0.20                 0.0
#               GAMA               DEPS0
                 0.0                 1.0
#ENDDATA
  1. The failure criteria is calculated as:(1)
    D f a i l = Δ D > 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiramaaBa aaleaacaWGMbGaamyyaiaadMgacaWGSbaabeaakiabg2da9maaqaea baGaeuiLdqKaamiraaWcbeqab0GaeyyeIuoakiabg6da+iaaigdaaa a@41BB@
    Where,(2)
    Δ D = Δ ε ¯ p ε ¯ p , f a i l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads eacqGH9aqpdaWcaaqaaiaabs5acuaH1oqzgaqeamaaBaaaleaacaWG WbaabeaaaOqaaiqbew7aLzaaraWaaSbaaSqaaiaadchacaGGSaGaam OzaiaadggacaWGPbGaamiBaaqabaaaaaaa@4433@
    Where,(3)
    ε ¯ p , f a i l = b ( 1 + c ) 1 n { [ 1 2 ( ( f 1 f 2 ) a + ( f 2 f 3 ) a + ( f 1 f 3 ) a ) ] 1 a + c ( 2 η + f 1 + f 3 ) } 1 n MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbae badaWgaaWcbaGaamiCaiaacYcacaWGMbGaamyyaiaadMgacaWGSbaa beaakiabg2da9iaadkgacqGHflY1daqadaqaaiaaigdacqGHRaWkca WGJbaacaGLOaGaayzkaaWaaWbaaSqabeaadaWcaaqaaiaaigdaaeaa caWGUbaaaaaakiabgwSixpaacmaabaWaamWaaeaadaWcaaqaaiaaig daaeaacaaIYaaaamaabmaabaWaaeWaaeaacaWGMbWaaSbaaSqaaiaa igdaaeqaaOGaeyOeI0IaamOzamaaBaaaleaacaaIYaaabeaaaOGaay jkaiaawMcaamaaCaaaleqabaGaamyyaaaakiabgUcaRmaabmaabaGa amOzamaaBaaaleaacaaIYaaabeaakiabgkHiTiaadAgadaWgaaWcba GaaG4maaqabaaakiaawIcacaGLPaaadaahaaWcbeqaaiaadggaaaGc cqGHRaWkdaqadaqaaiaadAgadaWgaaWcbaGaaGymaaqabaGccqGHsi slcaWGMbWaaSbaaSqaaiaaiodaaeqaaaGccaGLOaGaayzkaaWaaWba aSqabeaacaWGHbaaaaGccaGLOaGaayzkaaaacaGLBbGaayzxaaWaaW baaSqabeaadaWcaaqaaiaaigdaaeaacaWGHbaaaaaakiabgUcaRiaa dogadaqadaqaaiaaikdacqaH3oaAcqGHRaWkcaWGMbWaaSbaaSqaai aaigdaaeqaaOGaey4kaSIaamOzamaaBaaaleaacaaIYaaabeaaaOGa ayjkaiaawMcaaaGaay5Eaiaaw2haamaaCaaaleqabaGaeyOeI0YaaS aaaeaacaaIXaaabaGaamOBaaaaaaaaaa@789A@
    Where, f 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaaBa aaleaacaaIZaaabeaaaaa@37CA@ , f 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaaBa aaleaacaaIZaaabeaaaaa@37CA@ and f 3 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzamaaBa aaleaacaaIZaaabeaaaaa@37CA@ are functions of the Lode angle θ :(4)
    f 1 = 2 3 cos [ π 6 ( 1 θ ) ]
    (5)
    f 2 = 2 3 cos [ π 6 ( 3 + θ ) ]
    (6)
    f 3 = 2 3 cos [ π 6 ( 1 + θ ) ]
    With(7)
    θ = 1 2 π arccos [ 3 3 2 J 3 ( J 2 ) 3 / 2 ]
    Where, η is the traixiality η = σ m σ V M = I 1 3 3 J 2 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeq4TdGMaey ypa0ZaaSaaaeaacqaHdpWCdaWgaaWcbaGaamyBaaqabaaakeaacqaH dpWCdaWgaaWcbaGaamOvaiaad2eaaeqaaaaakiabg2da9maalaaaba GaamysamaaBaaaleaacaaIXaaabeaaaOqaaiaaiodadaGcaaqaaiaa iodacaWGkbWaaSbaaSqaaiaaikdaaeqaaaqabaaaaaaa@455F@ .
  2. The coefficient, b is computed as:
    b = b 0 [ 1 + γ ln ( ε ¯ ˙ p ε ¯ ˙ 0 ) ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOyaiabg2 da9iaadkgadaWgaaWcbaGaaGimaaqabaGcdaWadaqaaiaaigdacqGH RaWkcqaHZoWzciGGSbGaaiOBamaabmaabaWaaSaaaeaacuaH1oqzga qegaGaamaaBaaaleaacaWGWbaabeaaaOqaaiqbew7aLzaaryaacaWa aSbaaSqaaiaaicdaaeqaaaaaaOGaayjkaiaawMcaaaGaay5waiaaw2 faaaaa@4816@ if ε ¯ ˙ p > ε ¯ ˙ 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGafqyTduMbae HbaiaadaWgaaWcbaGaamiCaaqabaGccqGH+aGpcuaH1oqzgaqegaGa amaaBaaaleaacaaIWaaabeaaaaa@3C9D@ else b = b 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOyaiabg2 da9iaadkgadaWgaaWcbaGaaGimaaqabaaaaa@39B0@
  3. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL for brick. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL for brick).
