/PROP/TYPE5 (RIVET) (Obsolete)
Block Format Keyword Describes the rivet property set.
/PROP/TYPE5/prop_ID/unit_ID or /PROP/RIVET/prop_ID/unit_ID
prop_title
Fnmax Ftmax Lmax ω flag Iform
prop_ID Property identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
prop_title Property title
Fnmax Maximum normal force
(Real)
[ N ]
Ftmax Maximum tangential force
(Real)
[ N ]
Lmax Maximum length
If L > Lmax rivet is broken
(Real)
[ m ]
ω flag Rotations transmission flag
= 0
Rotations are not transmitted
= 1
Rotations are transmitted
(Integer)
Iform Formulation flag
= 1 (Default)
Rigid body formulation
= 2
Rigid link formulation
(Integer)
