/INTTHICK/V5 (Obsolete)
Block Format Keyword Shell Thickness defined in /SHELL and /SH3N format not taken into account by interface types 7, 10, 11, 18, 19 and 20. This option is used to allow behavior of versions prior to 10.0.
/INTTHICK/V5
  1. For gap and stiffness calculation for interface types 7, 10, 11, 18, 19, and 20 shell thickness defined in /SHELL and /SH3N formats are normally taken into account in version 10.0.
  2. If this option is used, gap and stiffness for interface types 7, 10, 11, 18, 19, and 20 are calculated according to the thickness given in the shell property for shells and 3-node shells.
