/UPWIND (Obsolete)
Block Format Keyword Describes the upwind coefficient.
/UPWIND
η 1 η 2 η 3
η 1 Upwind coefficient on ALE momentum transport
Default = 1.0 (Real)
η 2 Upwind coefficient on other ALE transports (mass, energy)
η 3 Upwind coefficient for wet area
  1. This option can be used for ALE or Eulerian cases (momentum upwind formulation can be reset by using /UPWM options during restart: refer to the Engine Input).
  2. η 3 is a coefficient for multi-phase law. η 3 is only available for /MAT/LAW51 (MULTIMAT).
