/ALE/SOLVER/FINT
Block Format Keyword This option defines the numerical method for internal force integration. This is relevant only for brick element and ALE legacy solver (momentum equation solved with FEM).
/ALE/SOLVER/FINT
Iform
Iform Integration method (internal force for brick elements) flag.
= 0
Set to 3.
= 1
Volume integration of the stress tensor using a shape function.
= 2
Surface integration for the hydrostatic stress tensor only.
= 3 (Default)
Surface integration for the stress tensor.
(Real)
  1. Momentum equation has local form:
    (1)
    ∂ ρ u ∂ t + d i v ( ρ u u ) = d i v ( σ ) + ρ g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai abgkGi2kabeg8aYjaahwhaaeaacqGHciITcaWG0baaaiabgUcaRiaa dsgacaWGPbGaamODamaabmaabaGaeqyWdiNaaCyDaiaahwhaaiaawI cacaGLPaaacqGH9aqpcaWGKbGaamyAaiaadAhadaqadaqaaiaaho8a aiaawIcacaGLPaaacqGHRaWkcqaHbpGCcaWHNbaaaa@5135@
    Iform is a flag defining the numerical method to compute d i v ( σ ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGKbGaam yAaiaadAhadaqadaqaaiaaho8aaiaawIcacaGLPaaaaaa@3D12@ when integrated over the cell with legacy solver (nodal velocities).
    Iform=1
    F int = ∫ Ω d i v ( σ ) d V MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHgbWaaS baaSqaaiGacMgacaGGUbGaaiiDaaqabaGccqGH9aqpdaWdXaqaaiaa dsgacaWGPbGaamODaiaacIcacaWHdpGaaiykaaWcbaGaeuyQdCfaba aaniabgUIiYdGccaWGKbGaamOvaaaa@474B@
    Was the default method up to Radioss version 2019.
    Iform=2
    F int = - ∫ ∂ Ω p d S + ∫ Ω d i v ( σ ) d V MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHgbWaaS baaSqaaiGacMgacaGGUbGaaiiDaaqabaGccqGH9aqpcaqGTaWaa8qm aeaacaWGWbaaleaacqGHciITcqqHPoWvaeaaa0Gaey4kIipakiaads gacaWHtbGaey4kaSYaa8qmaeaacaWGKbGaamyAaiaadAhacaGGOaGa aC4WdiaacMcaaSqaaiabfM6axbqaaaqdcqGHRiI8aOGaamizaiaadA faaaa@50BE@
    The integration method used with obsolete card /CAA (Obsolete)
    Iform=3
    F int = ∫ ∂ Ω ( - p I + σ d e v ) d S MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHgbWaaS baaSqaaiGacMgacaGGUbGaaiiDaaqabaGccqGH9aqpdaWdXaqaamaa bmaabaGaaeylaiaadchacaWHjbGaey4kaSIaaC4WdmaaBaaaleaaca WGKbGaamyzaiaadAhaaeqaaaGccaGLOaGaayzkaaaaleaacqGHciIT cqqHPoWvaeaaa0Gaey4kIipakiaadsgacaWHtbaaaa@4C6D@
    The integration method used as of Radioss version 2020.
    For volume integration, shape functions are used to compute at node, N:(2)
    F int i N = σ i k ∂ Φ N ∂ x k | 0 | Ω | MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHgbWaa0 baaSqaaiGacMgacaGGUbGaaiiDaaqaaiaadMgacaWGobaaaOGaeyyp a0Jaeq4Wdm3aaSbaaSqaaiaadMgacaWGRbaabeaakmaaeiaabaWaaS aaaeaacqGHciITcqqHMoGrdaWgaaWcbaGaamOtaaqabaaakeaacqGH ciITcaWG4bWaaSbaaSqaaiaadUgaaeqaaaaaaOGaayjcSdWaaSbaaS qaaiaaicdaaeqaaOWaaqWaaeaacqqHPoWvaiaawEa7caGLiWoaaaa@509D@
    Where, i = 1 , 3 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbGaey ypa0JaaGymaiaacYcacaaIZaaaaa@3B84@
    The value ∂ Φ N ∂ x k | 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaabcaqaam aalaaabaGaeyOaIyRaeuOPdy0aaSbaaSqaaiaad6eaaeqaaaGcbaGa eyOaIyRaamiEamaaBaaaleaacaWGRbaabeaaaaaakiaawIa7amaaBa aaleaacaaIWaaabeaaaaa@4166@ is taken at the integration point. It is assumed that:(3)
    ∂ Φ N 1 ∂ x j = − ∂ Φ N 7 ∂ x j   ;   ∂ Φ N 2 ∂ x j = − ∂ Φ N 8 ∂ x j   ;   ∂ Φ N 3 ∂ x j = − ∂ Φ N 5 ∂ x j   ;   ∂ Φ N 4 ∂ x j = − ∂ Φ N 6 ∂ x j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai abgkGi2kabfA6agnaaBaaaleaacaWGobGaaGymaaqabaaakeaacqGH ciITcaWG4bWaaSbaaSqaaiaadQgaaeqaaaaakiabg2da9iabgkHiTm aalaaabaGaeyOaIyRaeuOPdy0aaSbaaSqaaiaad6eacaaI3aaabeaa aOqaaiabgkGi2kaadIhadaWgaaWcbaGaamOAaaqabaaaaOGaaeiiai aacUdacaqGGaWaaSaaaeaacqGHciITcqqHMoGrdaWgaaWcbaGaamOt aiaaikdaaeqaaaGcbaGaeyOaIyRaamiEamaaBaaaleaacaWGQbaabe aaaaGccqGH9aqpcqGHsisldaWcaaqaaiabgkGi2kabfA6agnaaBaaa leaacaWGobGaaGioaaqabaaakeaacqGHciITcaWG4bWaaSbaaSqaai aadQgaaeqaaaaakiaabccacaGG7aGaaeiiamaalaaabaGaeyOaIyRa euOPdy0aaSbaaSqaaiaad6eacaaIZaaabeaaaOqaaiabgkGi2kaadI hadaWgaaWcbaGaamOAaaqabaaaaOGaeyypa0JaeyOeI0YaaSaaaeaa cqGHciITcqqHMoGrdaWgaaWcbaGaamOtaiaaiwdaaeqaaaGcbaGaey OaIyRaamiEamaaBaaaleaacaWGQbaabeaaaaGccaqGGaGaai4oaiaa bccadaWcaaqaaiabgkGi2kabfA6agnaaBaaaleaacaWGobGaaGinaa qabaaakeaacqGHciITcaWG4bWaaSbaaSqaaiaadQgaaeqaaaaakiab g2da9iabgkHiTmaalaaabaGaeyOaIyRaeuOPdy0aaSbaaSqaaiaad6 eacaaI2aaabeaaaOqaaiabgkGi2kaadIhadaWgaaWcbaGaamOAaaqa baaaaaaa@8735@
    This assumption is exact for parallelepipedic shape only, which is why the new default value method is set to surface integration (Iform=3).
