*MAT_003 (PLASTIC_KINEMATIC)
LS-DYNA Input Interface KeywordDefines an isotropic, elasto-plastic material with s Cowper-Symonds strain rate model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_003 or *MAT_PLASTIC_KINEMATIC | |||||||
| mat_ID | E | SIGY | ETAN | CHARD | |||
| SRC | SRP | EPS_F | |||||
Definition
| mat_ID | Material identifier. (Integer) |
| Initial density. (Real) |
| E | Young’s modulus. (Real) |
| Poisson’s ratio. (Real) |
| SIGY | Yield stress. (Real) |
| ETAN | Plastic slope. (Real) |
| CHARD | Hardening coefficient. (Real) |
| SRC | Cowper – Symond strain rate dependency
| SRP | Cowper – Symond strain rate dependency
exponent. (Real) |
| EPS_F | Failure plastic strain. (Real) |
- This keyword maps to /MAT/LAW44 (COWPER).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
