*MAT_S06 (SPRING_GENERAL_NONLINEAR)
LS-DYNA Input Interface KeywordThis keyword defines a nonlinear spring material with loading and unloading options.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_S06 or *MAT_SPRING_GENERAL_NONLINEAR | |||||||
mat_ID | LCL | LCU |
Definition
mat_ID | Material identifier (Integer) |
LCL | Loading curve identifier for force vs displacement or moment
vs rotation (Integer) |
or |
LCU | Unloading curve identifier for force vs displacement or
moment vs rotation (Integer) |
or |
- This keyword maps to /PROP/TYPE8 (SPR_GENE) spring using a default mass 2.0e-03 kg and inertia 2e-02 kg * mm depending on the units.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
