*MAT_007 (BLATZ_KO_RUBBER)
LS-DYNA Input Interface KeywordThis keyword defines an isotropic, incompressible, Neo-Hookean hyperelastic material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_007 or *MAT_BLATZ-KO_RUBBER | |||||||
mat_ID | G |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
G | Shear Modulus (Real) |
- This keyword maps to a New-Hookean incompressible material /MAT/LAW42 with Poisson's ratio = 0.463.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
