*BOUNDARY_SPC
LS-DYNA Input Interface KeywordDefine boundary conditions on nodes to fix translation and rotation.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *BOUNDARY_SPC_OPTION1_{OPTION2} | |||||||
| ID | Heading | ||||||
| NID/set_ID | CID | DOFX | DOFY | DOFZ | DOFXX | DOFYY | DOFZZ |
| OPTION1 | Boundary condition type. Required option.
(Character) |
| OPTION2 |
(Character) |
| ID | Optional ID. (Integer) |
| Heading | Boundary condition title . (Character) |
| NID/set_ID | Node ID or set ID. (Integer) |
| CID | Coordinate system identifier. (Integer) |
| DOFX, DOFY, DOFZ, DOFXX, DOFYY, DOFZZ | Constraint flag for the corresponding degrees of freedom:
- This card is mapped to /BCS card.
- Can not be used to constrain nodes that belong to a part with a rigid material *MAT_020.
