*MAT_024 (PIECEWISE_LINEAR_PLASTICITY)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress vs plastic strain input for different strain rates.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_024 or *MAT_PIECEWISE_LINEAR_PLASTICITY | |||||||
| mat_ID | E | SIGY | ETAN | FAIL | |||
| C | P | LCSS | LCSR | VP | |||
| EPS1 | EPS2 | EPS3 | EPS4 | EPS5 | EPS6 | EPS7 | EPS8 |
| ES1 | ES2 | ES3 | ES4 | ES5 | ES6 | ES7 | ES8 |
Definition
| mat_ID | Material Identifier (Integer) |
| Initial density (Real) |
| E | Young’s modulus (Real) |
| Poisson’s ratio Default = 0 (Real) |
| SIGY | Yield stress, ignored if LCSS>0 or
stress-strain values
EPS1-EPS8,
ES1-ES8
specified (Real) |
| ETAN | Plastic hardening modulus, not used if
LCSS>0 (Real) |
| FAIL | Plastic strain to failure (Real) |
| C | Strain rate coefficient (Real) |
| P | Strain rate exponent (Real) |
| LCSS | Stress vs plastic strain curve or table
identifier (Integer) |
| LCSR | Curve identifier defining the scaling coefficient for the
stress-strain curve for a corresponding strain
rate (Integer) |
| VP | Strain rate type flag:
(Integer) |
| EPS1-EPS8 | Plastic strain data points (Real) |
| ES1-ES8 | Yield stress data points (Real) |
- This keyword maps to /MAT/LAW36 (PLAS_TAB) when stress strain curves are specified using LCSS or EPS and ES. If SIGY, ETAN, C, and P are used then it maps to /MAT/LAW44 (COWPER).
- This material is only compatible with truss elements only when plasticity is specified through SIGY and ETAN.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
