Loading [MathJax]/jax/output/CommonHTML/jax.js
*SECTION_BEAM
LS-DYNA Input Interface KeywordDefines finite element property of beams, trusses, and discrete beams.
(1) (2) (3) (4) (5) (6) (7) (8)
*SECTION_BEAM
sec_ID ELFORM   NIP CST
If ELFORM = 1 (Integrated beam element), insert the following line.
TS1
If ELFORM = 2 (Resultant beam element), insert the following line.
A IYY IZZ IXX
If ELFORM = 3 (Truss element), insert the following line.
A
If ELFORM = 6 (Discrete beam element), insert the following line.
VOL INERTIA CID AREA
Definition
sec_ID Section identifier
(Integer)
ELFORM Beam element formulation
= 1 (Default)
= 2
= 3
Truss element
= 6
(Integer)
NIP Number of integration points (subsections)
= 2 (Default)
CST Cross section type
= 0
Square section
= 1
Circular section
TS1 Cross section dimension
If CST = 0
Edge of square section
If CST = 1
Diameter of circular section
(Real)
[m]
A Section area
(Real)
[m2]
IYY, IZZ Area moment of inertia for bending
(Real)
[m4]
IXX Area moment of inertia for torsion
(Real)
[m4]
VOL Discrete beam volume
(Real)
[m3]
INERTIA Discrete mass beam inertia
(Real)
[kgm2]
CID Coordinate system identifier for DOF directions of the discrete beams
(Integer)
AREA Section area of cable elements that use *MAT_071
(Real)
[m2]
  1. Converted into /PROP/TYPE3 (BEAM), /PROP/TYPE18 (INT_BEAM), /PROP/TYPE23 (SPR_MAT), or /PROP/TYPE2 (TRUSS).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
