*ELEMENT_DISCRETE
LS-DYNA Input Interface KeywordDefines a 1 degree of freedom spring element.
(1) (2) (3) (4) (5) (6) (7) (8)
*ELEMENT_DISCRETE
EID part_ID N1 N2 VID
Definition
EID Element identifier.
(Integer)
part_ID Part identifier.
(Integer)
N1, N2 Node identifier.
(Integer)
VID Direction identifier.
= 0 (Default)
The spring DOF is along N1-N2.
> 0
The spring DOF is defined by, *DEFINE_SD_ORIENTATION.
(Integer)
  1. This keyword maps to /SPRING.
