*CONSTRAINED_JOINT
LS-DYNA Input Interface KeywordDefine a joint between two rigid bodies.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONSTRAINED_JOINT_TYPE _{OPTION} |
JID | Title |
node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 |
Definition
TYPE |
OPTION | ID | |
JID | Joint ID (Integer) |
Title | Joint title (Character, maximum 70 characters) |
node_ID1 | Node identifier 1 for joint attached to rigid body
A (Integer) |
node_ID2 | Node identifier 2 for joint attached to rigid body
B (Integer) |
node_ID3 | Node identifier 3 for joint attached to rigid body
A (Integer) |
node_ID4 | Node identifier 4 for joint attached to rigid body
B (Integer) |
node_ID5 | Node identifier 5 for joint attached to rigid body
A (Integer) |
node_ID6 | Node identifier 6 for joint attached to rigid body
B (Integer) |
- This keyword maps to /SPRING, /PROP/TYPE45 (KJOINT2), and /PART.
- It is recommended to have node_ID1 and node_ID2 at the same initial position.
