*CONTACT_INTERIOR
LS-DYNA Input Interface KeywordDefine an interior contact for each part defined in the defined set of parts.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONTACT_INTERIOR | |||||||
| set_ID1 | set_ID2 | set_ID3 | set_ID4 | set_ID5 | set_ID6 | set_ID7 | set_ID8 |
Definition
| set_ID1 to set_ID8 | Set of part identifier (Integer) |
- This keyword maps to /INTER/TYPE7 with one interface defined per part in the set_IDs.
