*MAT_015 (JOHNSON_COOK)
LS-DYNA Input Interface KeywordThis model expresses material stress as a function of strain, strain rate, temperature dependency and plastic strain failure criterion.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_015 or *MAT_JOHNSON_COOK | |||||||
| mat_ID | E | v | |||||
| a | b | n | c | m | Tmelt | Tr | |
| CP | D1 | D2 | D3 | D4 | |||
| D5 | EROD | EFMIN | NUINT | ||||
Definition
| mat_ID | Material identifier (Integer) |
| Initial density (Real) |
| E | Young’s modulus (Real) |
| v | Poisson’s ratio (Real) |
| a | Yield stress (Real) |
| b | Plastic hardening parameter (Real) |
| n | Plastic hardening exponent (Real) |
| c | Strain rate coefficient (Real) |
| m | Temperature exponent Default = 1.00 (Real) |
| Tmelt | Melting temperature Default 1030 (Real) |
| Tr | Reference temperature. Default = 298 K (Real) |
| Reference strain rate (Real) |
| CP | Specific heat capacity (Real) |
| D1 | 1st parameter or Johnson failure model (Real) |
| D2 | 2nd parameter or Johnson failure model (Real) |
| D3 | 3rd parameter or Johnson failure model (Real) |
| D4 | 4th parameter or Johnson failure model (Real) |
| D5 | 5th parameter or Johnson failure model (Real) |
| EROD | Solid element erosion behavior
| EFMIN | Lower plastic strain failure model (Real) |
| NUINT | Number of integration point for shell element
erosion (Real) |
- This keyword maps to /MAT/LAW2 (PLAS_JOHNS) and /FAIL/JOHNSON.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
