*MAT_126 (MODIFIED_HONEYCOMB)
LS-DYNA Input Interface KeywordThis model expresses a three-dimension orthotropic nonlinear elasto-plastic material, usually used to model honeycomb or foam material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_126 or *MAT_MODIFIED_HONEYCOMB | |||||||
mat_ID | |||||||
fct_ID11 | fct_ID12 | fct_ID33 | fct_ID12 | fct_ID23 | fct_ID31 | fctIDsr | |
E11 | E22 | E33 | G12 | G23 | G31 | AOPT | |
A1 | A2 | A3 | |||||
D1 | D2 | D3 |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
fct_ID11 | Curve Identifier of yield stress function in direction
11. (Integer) |
fct_ID22 | Curve Identifier of yield stress function in direction
22. (Integer) |
fct_ID33 | Curve Identifier of yield stress function in direction
33. (Integer) |
fct_ID12 | Curve Identifier of yield stress function in direction
12. (Integer) |
fct_ID23 | Curve Identifier of yield stress function in direction
23. (Integer) |
fct_ID31 | Curve Identifier of yield stress function in direction
31. (Integer) |
fctIDsr | Curve identifier defining the strain rate yield scale factor
versus strain rate. (Integer) |
E11 | Young's modulus in direction 1. (Real) |
E22 | Young's modulus in direction 2. (Real) |
E33 | Young's modulus in direction 3. (Real) |
G12 | Shear modulus in direction 12. (Real) |
G23 | Shear modulus in direction 23. (Real) |
G31 | Shear modulus in direction 31. (Real) |
AOPT | Choice of orthotropy axis
(Integer) |
A1, A2, A3 | First orthotropy direction vector for AOPT
= 2 (Real) |
D1, D2, D3 | Vector components used with A1,
A2, A3 to determine
the 12 plane of orthotropy for AOPT =
2 (Real) |
- This keyword maps to /MAT/LAW50 (VISC_HONEY), /PROP/TYPE6 (SOL_ORTH), and /SKEW/FIX.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
