*MAT_S04 (SPRING_NONLINEAR_ELASTIC)
LS-DYNA Input Interface KeywordThis keyword defines a nonlinear elastic spring material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_S04 or *MAT_SPRING_NONLINEAR_ELASTIC | |||||||
mat_ID | LCL | LCR |
Definition
mat_ID | Material identifier (Integer) |
LCL | Curve identifier for force vs displacement or moment vs
rotation (Integer) |
or |
LCR | Curve identifier for the scale factor of force vs elongation
velocity or moment vs rotational velocity (Real) |
- This keyword maps to /PROP/TYPE8 (SPR_GENE) spring using a default mass 2.0e-03 kg and inertia 2e-02 kg * mm depending on units.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
