*MAT_181 (SIMPLIFIED_RUBBER/FOAM)
LS-DYNA Input Interface KeywordThis keyword defines a rubber and foam material with uniaxial tensile/compression test results as input curve. This material can be used with solid elements only.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_181 or *MAT_SIMPLIFIED_RUBBER/FOAM | |||||||
mat_ID | K | G | |||||
Length | Wide | Thick | Table_ID | Tension |
Fct_unl | Hys | Shape |
Definition
mat_ID | Material identifier (Integer) |
Poisson's ratio. (Real) |
K | Bulk modulus (Real) |
G | Shear modulus (Real) |
Length | Specimen gauge length (Real) |
Wide | Specimen gauge width (Real) |
Thick | Specimen gauge thickness (Real) |
Table_ID | Curve or table ID defining the force versus gauge length and
for the different strain rate value defined in the
table. (Integer) |
Tension | Unloading rate effects option flag.
(Integer) |
Fct_unl | Unloading curve ID (Integer) |
Hys | Hysteresis unloading factor. Ignore if, unloading function is
used. 0.0 ≤ Hys ≤ 1.0 Default = 0 (Real) |
Shape | Shape factor. Ignored if, unloading function is
used. Default = 1.0 (Real) |
- This keyword maps to /MAT/LAW70 (FOAM_TAB) for foam, and /MAT/LAW88 for the hyperelastic materials.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
