*MAT_066 (LINEAR_ELASTIC_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordThis keyword defines a linear elastic discrete beam material with 6 decoupled degrees of freedom and an optional preload option.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_066 or *MAT_LINEAR_ELASTIC_DISCRETE_BEAM | |||||||
mat_ID | TK_r | TK_s | TK_t | RK_r | RK_s | RK_t | |
TD_r | TD_s | TD_t | RD_r | RD_s | RD_t | ||
FO_r | FO_s | FO_t | MO_r | MO_s | MO_t |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
TK_r, TK_s, TK_t | Stiffness in directions r, s, t (Real) |
RK_r, RK_s, RK_t | Rotational stiffness for axis r, s, t (Real) |
TD_r, TD_s, TD_t | Damping in directions r, s, t (Real) |
RD_r, RD_s, RD_t | Rotational damping in directions r, s, t
(Real) |
FO_r, FO_s, FO_t | Force preload in directions r, s, t (Real) |
MO_r, MO_s, MO_t | Moment preload in directions r, s, t (Real) |
- This keyword maps to /MAT/LAW108 (SPR_GENE).
- The material is only used with *SECTION_BEAM, ELFORM = 6 discrete beam elements.
- Beams with zero initial length are recommended.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
