*MAT_071 (CABLE_DISCRETE_BEAM)
LS-DYNA Input Interface KeywordThis keyword defines an elastic cable material with no stiffness in compression.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_071 or *MAT_CABLE_DISCRETE_BEAM | |||||||
mat_ID | E | CID | F0 |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
E |
(Real) |
or |
CID | Curve identifier for engineering stress vs engineering strain
(Integer) |
F0 | Initial preload (tensile) force (Real) |
- This keyword maps to /MAT/LAW113 (SPR_BEAM).
- The material is only used with *SECTION_BEAM, ELFORM = 6 discrete beam elements.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
