*PART
LS-DYNA Input Interface KeywordDefines a part, which combines material and property information.
(1) (2) (3) (4) (5) (6) (7) (8)
*PART_{OPTION1}_{OPTION2}
part_title
part_ID sec_ID mat_ID
If OPTION1 = INERTIA, insert the following lines
XCOG YCOG ZCOG TM   node_ID
IXX IXY IXZ IYY IYZ IZZ
VTX VTY VTZ VRX VRY VRZ
If OPTION2 = CONTACT, insert the following line
        Thick
Definition
OPTION1
INERTIA
Optional flag to input mass, inertia and initial velocity for rigid components.
OPTION2
CONTACT
Optional flag to input contact thickness.
part_title Component title.
(Character, maximum 80 characters)
part_ID Part identifier.
(Integer)
sec_ID Section identifier of the elements in the part.
(Integer)
mat_ID Material identifier of the elements in the part.
(Integer)
XCOG, YCOG, ZCOG Coordinates of part center of gravity.
Default = 0 (Real)
TM Mass of rigid part.
Default = 0 (Real)
node_ID Node number for part center of gravity.
(Integer)
IXX, IXY, IXZ, IYY, IYZ, IZZ Inertia tensor of the rigid body.
Default = 0 (Real)
VTX, VTY, VTZ Initial translational velocity applied to the rigid component.
Default = 0 (Real)
VRX, VRY, VRZ Initial rotational velocity applied to the rigid component.
Default = 0 (Real)
Thick Optional part thickness in contact.
Default = 0 (Real)
  1. The *PART keyword maps to /PART
  2. The *PART_INERTIA keyword maps to /PART, /RBODY, and /INIVEL and the center of gravity, inertia, and mass of the part are calculated automatically by default. XCOG, YCOG, ZCOG are ignored, if node_ID is specified.
