/MAT/LAW113 (SPR_BEAM)
Block Format Keyword This beam type spring material works as a beam element with six independent modes of deformation. This spring accounts for nonlinear stiffness, damping and different unloading.
Deformation, force, and energy-based failure criteria are available. This material must be assigned to a /PART that references the spring property /PROP/TYPE23 (SPR_MAT).
/MAT/LAW113/mat_ID/unit_ID or /MAT/SPR_BEAM/mat_ID/unit_ID
mat_title
ρ
Ifail Ileng Ifail2
Loading index=1: Tension/Compression
K1 C1 A1 B1 D1
fct_ID11 H1 fct_ID21 fct_ID31 fct_ID41   δ min 1 δ max 1
F1 E1 Ascale1 Hscale1
Loading index=2: Shear XY
K2 C2 A2 B2 D2
fct_ID12 H2 fct_ID22 fct_ID32 fct_ID42   δ min 2 δ max 2
F2 E2 Ascale2 Hscale2
Loading index=3: Shear XZ
K3 C3 A3 B3 D3
fct_ID13 H3 fct_ID23 fct_ID33 fct_ID43   δ min 3 δ max 3
F3 E3 Ascale3 Hscale3
Loading index=4: Torsion
K4 C4 A4 B4 D4
fct_ID14 H4 fct_ID24 fct_ID34 fct_ID44   θ min 4 θ max 4
F4 E4 Ascale4 Hscale4
Loading index=5: Bending Y
K5 C5 A5 B5 D5
fct_ID15 H5 fct_ID25 fct_ID35 fct_ID45   θ min 5 θ max 5
F5 E5 Ascale5 Hscale5
Loading index=6: Bending Z
K6 C6 A6 B6 D6
fct_ID16 H6 fct_ID26 fct_ID36 fct_ID46   θ min 6 θ max 6
F6 E6 Ascale6 Hscale6
v 0 ω 0 Fcut Fsmooth
c1 n1 α 1 β 1
c2 n2 α 2 β 2
c3 n3 α 3 β 3
c4 n4 α 4 β 4
c5 n5 α 5 β 5
c6 n6 α 6 β 6
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρ Density.
(Real)
[ kg m 3 ]
Ifail Failure criteria.
= 0
Uni-directional criteria.
= 1
Multi-directional criteria.
(Integer)
Ileng Input per unit length flag. 4 5
= 0
Spring stiffness properties are input as explained in the definition table.
= 1
Spring properties are a function of engineering strain.
(Integer)
Ifail2 Failure model flag.
= 0 (Default)
Displacement and rotation criteria.
= 1
Displacement and rotation criteria with velocity rate effect.
= 2
Force and moment criteria.
= 3
Internal energy criteria.
(Integer)
Ki If fct_ID1i = 0: Linear loading and unloading stiffness.
If fct_ID1i ≠ 0: Only used as unloading stiffness for elasto-plastic springs.
i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3 are translation DOF.
i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6 are rotation DOF.
(Real)
[ N m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nm rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Ci Damping.
(Real)
[ Ns m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nms rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Ai Nonlinear stiffness function scale factor.
Default = 1.0 (Real)
[ N ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ Nm ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Bi Scale factor for logarithmic rate effects.
Default = 0.0 (Real)
Di Scale factor for logarithmic rate effects.
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ rad s ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
fct_ID1i Function identifier defining nonlinear stiffness f ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D3@ .
= 0
Linear spring with stiffness K.
If Hi =4: Function defines upper yield curve.
If Hi =8: Function is mandatory and defines the force or moment vs spring length.
(Integer)
Hi Spring Hardening flag for nonlinear spring.
= 0
Elastic spring.
= 1
Nonlinear elasto-plastic spring with isotropic hardening.
= 2
Nonlinear elasto-plastic spring with uncoupled hardening.
= 4
Nonlinear elastic plastic spring with kinematic hardening.
= 5
Nonlinear elasto-plastic spring with nonlinear unloading.
= 6
Nonlinear elasto-plastic spring with isotropic hardening and nonlinear unloading.
= 7
Nonlinear elastic plastic spring with elastic hysteresis.
(Integer)
fct_ID2i Function identifier defining force or moment as a function of spring velocity, g ( ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
fct_ID3i Function identifier.
If Hi =4: Defines lower yield curve.
If Hi =5: Defines residual displacement or rotation vs maximum displacement or rotation.
If Hi =6: Defines nonlinear unloading curve.
If Hi =7: Defines nonlinear unloading curve.
(Integer)
fct_ID4i Function identifier for nonlinear damping, h ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
δ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3BF0@ Negative translation failure limit.
Default = -1030 (Real)
If Ifail2 = 0 or 1: Failure displacement. [ m ]
If Ifail2 = 2: Failure force. [ N ]
If Ifail2 = 3: Failure internal energy. [ J ]
θ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3C01@ Negative rotational failure limit.
If Ifail2 = 0 or 1: Failure rotation. [ rad ]
If Ifail2 = 2: Failure moment. [ N ⋅ m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@
δ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaaaaa@3BF2@ Positive translation failure limit.
θ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaaaaa@3C03@ Positive rotational failure limit.
Fi Abscissa scale factor for the damping functions for the g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ and h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
Ei Ordinate scale factor for the damping function g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
(Real)
Ascalei Abscissa scale factor for the stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
[ m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ rad ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
Hscalei Ordinate scale factor for the damping function h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
v 0 Reference translational velocity.
ω 0 Reference rotational velocity.
[ rad s ]
Fcut Strain rate cutting frequency.
Default = 1030 (Real)
[Hz]
Fsmooth Smooth strain rate flag.
= 0 (Default)
Strain rate smoothing is inactive.
=1
Strain rate smoothing is active.
(Integer)
ci Relative velocity coefficient.
If Ifail2 = 0 or 1: Failure displacement or rotation. [ m ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
If Ifail2 = 2: Failure force or moment. [ N ] if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 1, 2, 3
[ N ⋅ m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@ if i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGPbaaaa@3856@ = 4, 5, 6
If Ifail2 = 3: Coefficient for failure internal energy. [ J ]
ni Relative velocity exponent.
α i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHXoqyda WgaaWcbaGaamyAaaqabaaaaa@3917@ Failure scale factor.
β i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaHYoGyda WgaaWcbaGaamyAaaqabaaaaa@3919@ Exponent.
Default = 2.0 (Real)
In this example beside mass and inertia just simple set stiffness for 6 DOF for this beam type of spring material.
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEM:
/UNIT/2
units for material and property
                  Mg                  mm                   s
/PROP/SPR_MAT/26/2
SPOTWELD_NO_RUPTURE
#    Imass                        Volume             Inertia   skew_ID   sens_ID    Isflag
         2                             1             6.55E-6         0         0         0
/MAT/LAW113/26/2
SPOTWELD_NO_RUPTURE
                2E-6
#    Ifail     Ileng    Ifail2
#                 K1                  C1                  A1                  B1                  D1
              100000                   0                   0                   0                   0
# fct_ID11        H1  fct_ID21  fct_ID31  fct_ID41                    delta_min1          delta_max1
         1         1         0         0         0                             0               .5E-1
#                 F1                  E1             Ascale1             Hscale1
                   0                   0                   0                   0
#                 K2                  C2                  A2                  B2                  D2
              500000                   0                   0                   0                   0
# fct_ID12        H2  fct_ID22  fct_ID32  fct_ID42                    delta_min2          delta_max2
         2         1         0         0         0                        -.5E-1               .5E-1
#                 F2                  E2             Ascale2             Hscale2
                   0                   0                   0                   0
#                 K3                  C3                  A3                  B3                  D3
              500000                   0                   0                   0                   0
# fct_ID13        H3  fct_ID23  fct_ID33  fct_ID43                    delta_min3          delta_max3
         2         1         0         0         0                        -.5E-2               .5E-2
#                 F3                  E3             Ascale3             Hscale3
                   0                   0                   0                   0
#                 K4                  C4                  A4                  B4                  D4
             5000000                   0                   0                   0                   0
# fct_ID14        H4  fct_ID24  fct_ID34  fct_ID44                    delta_min4          delta_max4
         0         1         0         0         0                         -.015                .015
#                 F4                  E4             Ascale4             Hscale4
                   0                   0                   0                   0
#                 K5                  C5                  A5                  B5                  D5
             5000000                   0                   0                   0                   0
# fct_ID15        H5  fct_ID25  fct_ID35  fct_ID45                    delta_min5          delta_max5
#                 F5                  E5             Ascale5             Hscale5
                   0                   0                   0                   0
#                 K6                  C6                  A6                  B6                  D6
             5000000                   0                   0                   0                   0
# fct_ID16        H6  fct_ID26  fct_ID36  fct_ID46                    delta_min6          delta_max6
#                 F6                  E6             Ascale6             Hscale6
                   0                   0                   0                   0
#                 V0              Omega0               F_cut   Fsmooth
                   0                   0                   0         0
#                  C                   n               alpha                beta
                   0                   0                   0                   0
                   0                   0                   0                   0
                   0                   0                   0                   0
                   0                   0                   0                   0
                   0                   0                   0                   0
                   0                   0                   0                   0
#-  7. FUNCTIONS:
/FUNCT/1
spotweld tensile function
#                  X                   Y
              -250.0             -8250.0
               -0.25             -8250.0
                 0.0                 0.0
                0.25              8250.0
               250.0              8250.0
/FUNCT/2
Spotweld shear function
#                  X                   Y
              -250.0            -25000.0
               -0.25            -25000.0
                 0.0                 0.0
                0.25             25000.0
               250.0             25000.0
#enddata
  1. When used with /PROP/TYPE23 (SPR_MAT), this material law has the same behavior as spring property /PROP/SPR_BEAM.
  2. Inputs repeated for each degree of freedom (DOF) i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ are defined with the following directions:
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1: tension/compression
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =2: shear xy
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =3: shear xz
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4: torsion
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =5: bending y
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =6: bending z
  3. The spring's X MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHybaaaa@373F@ direction is defined using nodes N1 and N2 of the spring.
    If the node of the spring N3 is defined, the spring's Y ′ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaceWHzbGbau aaaaa@374C@ direction is defined using nodes N1 and N3 of the spring. N3, N2, and N1 should not be in a line.
    prop_spr_beam14
    • The Z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHAbaaaa@3741@ direction is:(1)
      Z = X Λ Y ′
    • If node N3 is not defined in the element input, and skew system is defined in the /PROP/TYPE23 (SPR_MAT) input, the Z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHAbaaaa@3741@ direction is:(2)
      Z = X Λ Y skew
    • If neither node N3 nor skew system are defined in input, the Z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHAbaaaa@3741@ direction is:(3)
      Z = X Λ Y global
    Except when the spring local X MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHzbaaaa@3740@ direction and Y g l o b a l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHzbWaaS baaSqaaiaadEgacaWGSbGaam4BaiaadkgacaWGHbGaamiBaaqabaaa aa@3CFC@ are colinear then:(4)
    Z = X Λ X global
    Finally, Y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWHzbaaaa@3740@ direction is found as:(5)
    Y = Z Λ X
  4. If Ileng = 1, the spring stiffness properties are related on the initial spring length. The input should be entered as:
    K = k * l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGlbGaey ypa0Jaam4AaiaacQcacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3BA9@
    C = c * l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGdbGaey ypa0Jaam4yaiaacQcacaWGSbWaaSbaaSqaaiaaicdaaeqaaaaa@3B99@
    Each spring will then have the following properties in the model:
    k = K l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGRbGaey ypa0ZaaSaaaeaacaWGlbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3B0B@
    c = C l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbGaey ypa0ZaaSaaaeaacaWGdbaabaGaamiBamaaBaaaleaacaaIWaaabeaa aaaaaa@3AFB@
    Where,
    K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and C MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring values entered in the spring property fields
    k MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ and c MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@
    Spring’s actual physical mass, inertia, stiffness and damping
    l 0
    Initial spring length which is the distance between node N1 and N2 of the spring
    δ min 1  and  δ max 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaaGymaaaakiaabccacaqG HbGaaeOBaiaabsgacaqGGaGaeqiTdq2aa0baaSqaaiGac2gacaGGHb GaaiiEaaqaaiaaigdaaaaaaa@452A@
    Failure values entered as engineering strain
  5. Force and moment computation. For additional information, refer to Stiffness Formulation in the User Guide.
    If Ileng = 0, translational DOFs i =1,2,3 - use displacement to determine spring forces and use rotational angle in radians for rotational DOFs i =4,5,6 to determine spring moments.
    The values of forces and moments in the spring are computed as:
    • Linear spring:
      F ( δ ) = K i δ i + C i δ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiTdq2aaWbaaSqabeaacaWGPbaaaOGaey4kaS Iaam4qamaaBaaaleaacaWGPbaabeaakiqbes7aKzaacaWaaWbaaSqa beaacaWGPbaaaaaa@45B3@ with i =1,2,3
      M ( θ ) = K i θ i + C i θ ˙ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpcaWGlbWaaSbaaSqa aiaadMgaaeqaaOGaeqiUde3aaWbaaSqabeaacaWGPbaaaOGaey4kaS Iaam4qamaaBaaaleaacaWGPbaabeaakiqbeI7aXzaacaWaaWbaaSqa beaacaWGPbaaaaaa@45ED@ with i =4,5,6
    • Nonlinear spring:
      F ( δ ) = f ( δ i A s c a l e i ) [ A i + B i ln | δ ˙ i D i | + E i g ( δ ˙ i F i ) ] + C i δ ˙ i + H s c a l e i h ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpciGGMbWaaeWaaeaa daWcaaqaaiabes7aKnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeaca WGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaa aaaakiaawIcacaGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaa qabaGccqGHRaWkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaa c6gadaabdaqaamaalaaabaGafqiTdqMbaiaadaahaaWcbeqaaiaadM gaaaaakeaacaWGebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaa wIa7aiabgUcaRiaadweadaWgaaWcbaGaamyAaaqabaGcciGGNbWaae WaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaai aawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaSqaaiaadMgaaeqaaOGa fqiTdqMbaiaadaahaaWcbeqaaiaadMgaaaGccqGHRaWkcaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaGc ciGGObWaaeWaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaaca WGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaaaaa@762D@ with i =1,2,3
      M ( θ ) = f ( θ i A s c a l e i ) [ A i + B i ln | θ ˙ i D i | + E i g ( θ ˙ i F i ) ] + C i θ ˙ i + H s c a l e i h ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpciGGMbWaaeWaaeaa daWcaaqaaiabeI7aXnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeaca WGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaa aaaakiaawIcacaGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaa qabaGccqGHRaWkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaa c6gadaabdaqaamaalaaabaGafqiUdeNbaiaadaahaaWcbeqaaiaadM gaaaaakeaacaWGebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaa wIa7aiabgUcaRiaadweadaWgaaWcbaGaamyAaaqabaGcciGGNbWaae WaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaai aawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaSqaaiaadMgaaeqaaOGa fqiUdeNbaiaadaahaaWcbeqaaiaadMgaaaGccqGHRaWkcaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaGc ciGGObWaaeWaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaaca WGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaaaaa@769A@ with i =4,5,6
      Where,
      • δ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda ahaaWcbeqaaiaadMgaaaaaaa@391E@ (with − l 0 < δ i < + ∞ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqGHsislca WGSbWaaSbaaSqaaiaaicdaaeqaaOGaeyipaWJaeqiTdq2aaWbaaSqa beaacaWGPbaaaOGaeyipaWJaey4kaSIaeyOhIukaaa@4051@ ) is the difference between the current length l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbaaaa@374F@ and the initial length l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbWaaS baaSqaaiaaicdaaeqaaaaa@3835@ of the spring element for corresponding translational DOF.
      • θ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda ahaaWcbeqaaiaadMgaaaaaaa@392F@ is the relative angle for corresponding rotational DOF in radians.
      • For linear springs, f ( δ ) , ​   g ( δ ˙ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacaGGSaGaaGzaVlaaysW7ciGG NbWaaeWaaeaacuaH0oazgaGaaaGaayjkaiaawMcaaaaa@4263@ and h ( δ ˙ ) , ( f ( θ ) ,   g ( θ ˙ )   and h ( θ ˙ ) ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaacuaH0oazgaGaaaGaayjkaiaawMcaaiaacYcadaqadaqaaiGa cAgadaqadaqaaiabeI7aXbGaayjkaiaawMcaaiaacYcacaaMe8Uaci 4zamaabmaabaGafqiUdeNbaiaaaiaawIcacaGLPaaacaaMe8Uaaeyy aiaab6gacaqGKbGaciiAamaabmaabaGafqiUdeNbaiaaaiaawIcaca GLPaaaaiaawIcacaGLPaaaaaa@4FD8@ are zero functions and A i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ , B i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ , E i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ and H s c a l e i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaaa aa@3CE6@ are not taken into account.
      • If stiffness function f ( δ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaaaaa@3A78@ or f ( θ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaaaaa@3A89@ is requested, then K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is used as a slope for unloading only.
      • If K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is lower than the maximum slop of function f ( δ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaaaaa@3A78@ or f ( θ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaaaaa@3A89@ ( K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is not consistent with the maximum slope of the curve), K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is set to the maximum slope of the curve.
    If Ileng = 1, translational DOFs i =1,2,3 - use engineering strain (elongation per unit length) to determine spring forces and use rotational per unit length for rotational DOFs i =4,5,6 to determine spring moments. Spring parameters are related to initial spring length.
    The forces and moments in the spring are computed as:
    • F ( ε ) = f ( ε i A s c a l e i ) [ A i + B i ln ( max ( 1 , | ε ˙ i D i | ) ) + E i g ( ε ˙ i F i ) ] + C i ε ˙ i + H s c a l e i h ( ε ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH1oqzaiaawIcacaGLPaaacqGH9aqpciGGMbWaaeWaaeaa daWcaaqaaiabew7aLnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeaca WGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaa aaaakiaawIcacaGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaa qabaGccqGHRaWkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaa c6gadaqadaqaaiGac2gacaGGHbGaaiiEamaabmaabaGaaGymaiaacY cadaabdaqaamaalaaabaGafqyTduMbaiaadaahaaWcbeqaaiaadMga aaaakeaacaWGebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaawI a7aaGaayjkaiaawMcaaaGaayjkaiaawMcaaiabgUcaRiaadweadaWg aaWcbaGaamyAaaqabaGcciGGNbWaaeWaaeaadaWcaaqaaiqbew7aLz aacaWaaWbaaSqabeaacaWGPbaaaaGcbaGaamOramaaBaaaleaacaWG PbaabeaaaaaakiaawIcacaGLPaaaaiaawUfacaGLDbaacqGHRaWkca WGdbWaaSbaaSqaaiaadMgaaeqaaOGafqyTduMbaiaadaahaaWcbeqa aiaadMgaaaGccqGHRaWkcaWGibGaam4CaiaadogacaWGHbGaamiBai aadwgadaWgaaWcbaGaamyAaaqabaGcciGGObWaaeWaaeaadaWcaaqa aiqbew7aLzaacaWaaWbaaSqabeaacaWGPbaaaaGcbaGaamOramaaBa aaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaaaa@7D8A@ with i =1,2,3
    • M ( θ l 0 ) = f ( θ l 0 i A s c a l e i ) [ A i + B i ln ( max ( 1 , | θ ˙ l 0 i D i | ) ) + E i g ( θ ˙ l 0 i F i ) ] + C i θ l 0 i + H s c a l e i h ( θ ˙ l 0 i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaadaWcaaqaaiabeI7aXbqaaiaadYgadaWgaaWcbaGaaGimaaqa baaaaaGccaGLOaGaayzkaaGaeyypa0JaciOzamaabmaabaWaaSaaae aadaWcaaqaaiabeI7aXbqaaiaadYgadaWgaaWcbaGaaGimaaqabaaa aOWaaWbaaSqabeaacaWGPbaaaaGcbaGaamyqaiaadohacaWGJbGaam yyaiaadYgacaWGLbWaaSbaaSqaaiaadMgaaeqaaaaaaOGaayjkaiaa wMcaamaadmaabaGaamyqamaaBaaaleaacaWGPbaabeaakiabgUcaRi aadkeadaWgaaWcbaGaamyAaaqabaGcciGGSbGaaiOBamaabmaabaGa ciyBaiaacggacaGG4bWaaeWaaeaacaaIXaGaaiilamaaemaabaWaaS aaaeaadaWcaaqaaiqbeI7aXzaacaaabaGaamiBamaaBaaaleaacaaI WaaabeaaaaGcdaahaaWcbeqaaiaadMgaaaaakeaacaWGebWaaSbaaS qaaiaadMgaaeqaaaaaaOGaay5bSlaawIa7aaGaayjkaiaawMcaaaGa ayjkaiaawMcaaiabgUcaRiaadweadaWgaaWcbaGaamyAaaqabaGcci GGNbWaaeWaaeaadaWcaaqaamaalaaabaGafqiUdeNbaiaaaeaacaWG SbWaaSbaaSqaaiaaicdaaeqaaaaakmaaCaaaleqabaGaamyAaaaaaO qaaiaadAeadaWgaaWcbaGaamyAaaqabaaaaaGccaGLOaGaayzkaaaa caGLBbGaayzxaaGaey4kaSIaam4qamaaBaaaleaacaWGPbaabeaakm aalaaabaGaeqiUdehabaGaamiBamaaBaaaleaacaaIWaaabeaaaaGc daahaaWcbeqaaiaadMgaaaGccqGHRaWkcaWGibGaam4Caiaadogaca WGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaGcciGGObWaaeWa aeaadaWcaaqaamaalaaabaGafqiUdeNbaiaaaeaacaWGSbWaaSbaaS qaaiaaicdaaeqaaaaakmaaCaaaleqabaGaamyAaaaaaOqaaiaadAea daWgaaWcbaGaamyAaaqabaaaaaGccaGLOaGaayzkaaaaaa@8988@ with i =4,5,6
    Where,
    ε i = δ i l 0
    Engineering strain
    θ l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaWcaaqaai abeI7aXbqaaiaadYgadaWgaaWcbaGaaGimaaqabaaaaaaa@39FB@
    Rotation divided by the original spring length
  6. Time step calculation.
    • Time step for translational DOF is computed as:(6)
      Δ t i = M ⋅ max ( K i ) + C i 2 − C i max ( K i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqqHuoarca WG0bWaaSbaaSqaaiaadMgaaeqaaOGaeyypa0ZaaSaaaeaadaGcaaqa aiaad2eacqGHflY1ciGGTbGaaiyyaiaacIhacaGGOaGaam4samaaBa aaleaacaWGPbaabeaakiaacMcacqGHRaWkcaWGdbWaaSbaaSqaaiaa dMgaaeqaaOWaaWbaaSqabeaacaaIYaaaaaqabaGccqGHsislcaWGdb WaaSbaaSqaaiaadMgaaeqaaaGcbaGaciyBaiaacggacaGG4bGaaiik aiaadUeadaWgaaWcbaGaamyAaaqabaGccaGGPaaaaaaa@50FF@
      with i =1, 2, 3
    • Time step for rotational DOF is computed as:(7)
      Δ t i = I ⋅ max ( K ' i ) + C ' i 2 − C ' i max ( K ' i )
      with i =4, 5, 6
    Where,
    K ' i = max ( K t ) ⋅ L 2 + max ( K i )
    C ' i = max ( C t ) ⋅ L 2 + max ( C i )
    with i =1, 2, 3 and i =4, 5, 6 and min ( Δ t i ) is used as spring time step.
  7. Failure criteria:
    • For uni-directional failure criteria Ifail=0, the spring fails as soon as one of the criteria is met in one direction:(8)
      α i ( δ i δ max i ) ≥ 1
      or(9)
      α i | δ i δ min i | ≥ 1
      with δ max i and δ min i being the failure limits in direction i =1,2,3(10)
      α i ( θ i θ max i ) ≥ 1
      or(11)
      α i | θ i θ min i | ≥ 1
      with θ max i and θ min i being the failure limits in direction i =4,5,6
      For each direction δ min i (or θ min i ) should be negative and δ max i (or θ max i ) should be positive. If the values are zero, then no failure will be considered.
    • For multi-directional failure criteria Ifail=1, the spring fails when the following criteria is fulfilled:(12)
      ∑ i = 1 , 2 , 3 α i ( δ i δ f a i l i ) β i + ∑ i = 4 , 5 , 6 α i ( θ i θ f a i l i ) β i ≥ 1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaadaaeqbqaai abeg7aHnaaBaaaleaacaWGPbaabeaakmaabmaabaWaaSaaaeaacqaH 0oazdaahaaWcbeqaaiaadMgaaaaakeaacqaH0oazdaqhaaWcbaGaam OzaiaadggacaWGPbGaamiBaaqaaiaadMgaaaaaaaGccaGLOaGaayzk aaaaleaacaWGPbGaeyypa0JaaGymaiaacYcacaaIYaGaaiilaiaaio daaeqaniabggHiLdGcdaahaaWcbeqaaiabek7aInaaBaaameaacaWG PbaabeaaaaGccqGHRaWkdaaeqbqaaiabeg7aHnaaBaaaleaacaWGPb aabeaakmaabmaabaWaaSaaaeaacqaH4oqCdaahaaWcbeqaaiaadMga aaaakeaacqaH4oqCdaqhaaWcbaGaamOzaiaadggacaWGPbGaamiBaa qaaiaadMgaaaaaaaGccaGLOaGaayzkaaaaleaacaWGPbGaeyypa0Ja aGinaiaacYcacaaI1aGaaiilaiaaiAdaaeqaniabggHiLdGcdaahaa Wcbeqaaiabek7aInaaBaaameaacaWGPbaabeaaaaGccqGHLjYScaaI Xaaaaa@6A7C@
      • For "old" displacement formulation (Ifail2 = 0), the coefficients α i and β i are equal to 1.0 and 2.0, respectively.
      • The new displacement formulation (Ifail2 =1) allows to model velocity dependent failure limit for translational DOF:(13)
        δ f a i l i = { δ max i + c i ⋅ | v i v 0 | n i , i f ( δ i > 0 ) δ min i − c i ⋅ | v i v 0 | n i , i f ( δ i ≤ 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaamOzaiaadggacaWGPbGaamiBaaqaaiaadMgaaaGccqGH 9aqpdaGabaqaauaabeqaceaaaeaacqaH0oazdaqhaaWcbaGaciyBai aacggacaGG4baabaGaamyAaaaakiabgUcaRiaadogadaWgaaWcbaGa amyAaaqabaGccqGHflY1daabdaqaamaalaaabaGaamODamaaCaaale qabaGaamyAaaaaaOqaaiaadAhadaWgaaWcbaGaaGimaaqabaaaaaGc caGLhWUaayjcSdWaaWbaaSqabeaacaWGUbGaamyAaaaakiaacYcaca WGPbGaamOzamaabmaabaGaeqiTdq2aaWbaaSqabeaacaWGPbaaaOGa eyOpa4JaaGimaaGaayjkaiaawMcaaaqaaiabes7aKnaaDaaaleaaci GGTbGaaiyAaiaac6gaaeaacaWGPbaaaOGaeyOeI0Iaam4yamaaBaaa leaacaWGPbaabeaakiabgwSixpaaemaabaWaaSaaaeaacaWG2bWaaW baaSqabeaacaWGPbaaaaGcbaGaamODamaaBaaaleaacaaIWaaabeaa aaaakiaawEa7caGLiWoadaahaaWcbeqaaiaad6gacaWGPbaaaOGaai ilaiaadMgacaWGMbWaaeWaaeaacqaH0oazdaahaaWcbeqaaiaadMga aaGccqGHKjYOcaaIWaaacaGLOaGaayzkaaaaaaGaay5Eaaaaaa@794D@
        with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1,2,3(14)
        θ i f a i l = { θ max i + c i ⋅ | ω i ω 0 | n i ,   i f     ( θ i > 0 ) θ min i − c i ⋅ | ω i ω 0 | n i ,   i f     ( θ i ≤ 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda ahaaWcbeqaaiaadMgaaaGcdaWgaaWcbaGaamOzaiaadggacaWGPbGa amiBaaqabaGccqGH9aqpdaGabaqaauaabeqaceaaaeaacqaH4oqCda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaakiabgUcaRiaa dogadaWgaaWcbaGaamyAaaqabaGccqGHflY1daabdaqaamaalaaaba GaeqyYdC3aaWbaaSqabeaacaWGPbaaaaGcbaGaeqyYdC3aaSbaaSqa aiaaicdaaeqaaaaaaOGaay5bSlaawIa7amaaCaaaleqabaGaamOBai aadMgaaaGccaGGSaGaaGjbVlaadMgacaWGMbGaaGjbVlaaykW7daqa daqaaiabeI7aXnaaCaaaleqabaGaamyAaaaakiabg6da+iaaicdaai aawIcacaGLPaaaaeaacqaH4oqCdaqhaaWcbaGaciyBaiaacMgacaGG UbaabaGaamyAaaaakiabgkHiTiaadogadaWgaaWcbaGaamyAaaqaba GccqGHflY1daabdaqaamaalaaabaGaeqyYdC3aaWbaaSqabeaacaWG PbaaaaGcbaGaeqyYdC3aaSbaaSqaaiaaicdaaeqaaaaaaOGaay5bSl aawIa7amaaCaaaleqabaGaamOBaiaadMgaaaGccaGGSaGaaGjbVlaa dMgacaWGMbGaaGjbVlaaykW7daqadaqaaiabeI7aXnaaCaaaleqaba GaamyAaaaakiabgsMiJkaaicdaaiaawIcacaGLPaaaaaaacaGL7baa aaa@866A@
        with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4,5,6
        Where, δ min i or δ max i is the static displacement failure limit (Lines 5, 8 and 11), and ν 0 is the reference velocity.
        Where, θ min i or θ max i is the static rotation failure limit (Lines 14, 17 and 20), and ω 0 is the reference velocity.
        Relative velocity coefficients, c i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS baaSqaaiaadMgaaeqaaaaa@3860@ (with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1,2,3) have the units of displacement and c i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS baaSqaaiaadMgaaeqaaaaa@3860@ (with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4,5,6) have the units of rotation.
      • Force or moment failure criteria is activated with Ifail2=2:(15)
        δ i f a i l = { δ max i + c i ⋅ | v i v 0 | n i , i f ( δ i > 0 ) δ min i − c i ⋅ | v i v 0 | n i , i f ( δ i ≤ 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda ahaaWcbeqaaiaadMgaaaGcdaWgaaWcbaGaamOzaiaadggacaWGPbGa amiBaaqabaGccqGH9aqpdaGabaqaauaabeqaceaaaeaacqaH0oazda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaakiabgUcaRiaa dogadaWgaaWcbaGaamyAaaqabaGccqGHflY1daabdaqaamaalaaaba GaamODamaaCaaaleqabaGaamyAaaaaaOqaaiaadAhadaWgaaWcbaGa aGimaaqabaaaaaGccaGLhWUaayjcSdWaaWbaaSqabeaacaWGUbGaam yAaaaakiaacYcacaWGPbGaamOzamaabmaabaGaeqiTdq2aaWbaaSqa beaacaWGPbaaaOGaeyOpa4JaaGimaaGaayjkaiaawMcaaaqaaiabes 7aKnaaDaaaleaaciGGTbGaaiyAaiaac6gaaeaacaWGPbaaaOGaeyOe I0Iaam4yamaaBaaaleaacaWGPbaabeaakiabgwSixpaaemaabaWaaS aaaeaacaWG2bWaaWbaaSqabeaacaWGPbaaaaGcbaGaamODamaaBaaa leaacaaIWaaabeaaaaaakiaawEa7caGLiWoadaahaaWcbeqaaiaad6 gacaWGPbaaaOGaaiilaiaadMgacaWGMbWaaeWaaeaacqaH0oazdaah aaWcbeqaaiaadMgaaaGccqGHKjYOcaaIWaaacaGLOaGaayzkaaaaaa Gaay5Eaaaaaa@7983@
        with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1,2,3 for force criteria(16)
        with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4,5,6 for moment criteria
        Where, δ min i or δ max i is the static failure limit force (Lines 5, 8, and 11) and ν 0 is the reference velocity.
        Where, θ min i or θ max i is the static failure limit moment (Lines 14, 17 and 20), and ω 0 is the reference velocity.
        Relative velocity coefficients, c i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS baaSqaaiaadMgaaeqaaaaa@3860@ (with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1,2,3) have the units of force and c i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS baaSqaaiaadMgaaeqaaaaa@3860@ (with i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4,5,6) have the units of momentum.
      • Energy failure criteria is activated with Ifail2= 3:(17)
        δ i f a i l = δ max i + c i ⋅ | v i v 0 | n i , i f ( δ i > 0 )
        (18)
        θ i f a i l = θ max i + c i ⋅ | ω i ω 0 | n i , i f ( θ i > 0 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda ahaaWcbeqaaiaadMgaaaGcdaWgaaWcbaGaamOzaiaadggacaWGPbGa amiBaaqabaGccqGH9aqpcqaH4oqCdaqhaaWcbaGaciyBaiaacggaca GG4baabaGaamyAaaaakiabgUcaRiaadogadaWgaaWcbaGaamyAaaqa baGccqGHflY1daabdaqaamaalaaabaGaeqyYdC3aaWbaaSqabeaaca WGPbaaaaGcbaGaeqyYdC3aaSbaaSqaaiaaicdaaeqaaaaaaOGaay5b SlaawIa7amaaCaaaleqabaGaamOBaiaadMgaaaGccaGGSaGaamyAai aadAgadaqadaqaaiabeI7aXnaaCaaaleqabaGaamyAaaaakiabg6da +iaaicdaaiaawIcacaGLPaaaaaa@5CB4@
        Where, δ max i is the static failure limit translational energy (Lines 5, 8, and 11) and ν 0 is the reference velocity.
        Where, θ max i is the static failure limit rotational energy (Lines 14, 17 and 20), and ω 0 is the reference velocity.
        In this case, the displacement values are replaced by positive failure energy values and the rotation values are replaced by positive failure energy values.
        Relative velocity coefficients, c i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGJbWaaS baaSqaaiaadMgaaeqaaaaa@3860@ have the units of energy.
  8. Spring elements with sensor activation or deactivation are mainly used in the pretension models.
