/MAT/LAW0 (VOID)
Block Format Keyword This material can be used to define elements to act as a void, or an empty space.
/MAT/LAW0/mat_ID/unit_ID or /MAT/VOID/mat_ID/unit_ID
mat_title
Optional
ρ E υ
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
mat_title Material title
ρ Initial density
(Real)
[ kg m 3 ]
E Young's modulus
(Real)
[ Pa ]
υ Poisson's ratio
(Real)
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  Mg                  mm                   s
#-  2. MATERIALS:
/MAT/VOID/1/1
Void
#                RHO                   E                  Nu
             7.85E-9              210000                 0.3
#ENDDATA
/END
  1. Only law, mat_ID, and mat_title are used (refer to the keyword Materials).
  2. This additional data allows defining contact interfaces with void material and property: all kinds of input for interfaces will then be available (Igap =1, Stfac as a stiffness factor).
  3. Contact stiffness will be correctly calculated only when E, υ and t (thickness in property) are given.
  4. When density of the void material is defined, the mass of the material is accounted in kinetic energy calculation.
