/MAT/LAW1 (ELAST)
Block Format Keyword This keyword defines an isotropic, linear elastic material using Hooke's law. This law represents a linear relationship between stress and strain. It is available for truss, beam (type 3 only), shell and solid elements.
| /MAT/LAW1/mat_ID/unit_ID or /MAT/ELAST/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | |||||||||
| mat_ID | Material identifier (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| mat_title | Material title (Character, maximum 100 characters) |
| Initial density (Real) |
| E | Young's modulus (Real) |
| Poisson's ratio (Real) |
Example (Elastic - Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/ELAST/1/1
Steel
# RHO_I
7.85E-9 0
# E nu
210000 .3
#ENDDATA
/END
- This material law is used to model
purely elastic materials. The material stiffness is determined by only two values: the
Young's modulus (E), and Poisson's ratio (
). The shear modulus (G) can be computed using E and
, as:
(1) - The stress-strain relationship can be
represented as shown:
(2) - The value of density is always used in explicit simulations and it may also be used in static implicit simulations to reach a better convergence in quasi-static analysis.
- Global integration approach is applied
to LAW1 and shell elements (/PROP/TYPE1 (SHELL)), when the number of
integration points through the shell thickness is different from NP=1
(membranes).Note: Failure models are not available in the case of global integration. LAW2 and LAW27 with very high yield stress may be used as a substitution to LAW1 in these cases.
