/MAT/LAW71
Block Format Keyword This law describes the behavior of superelastic materials. It allows modeling the behavior of the shape memory alloys (such as Nitinol).
The particularity of these materials is that all of the strain is recovered upon unloading even when large deformations are reached. Besides, the material shows a hysteretic response in a complete loading-unloading cycle. The full recovery is due to phase change in the microstructure. The model is based on the work of Auricchio et al. 1997. This law is compatible with solid and shell elements.
/MAT/LAW71/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
E | E_mart | ||||||||
EpsL | CAS | CSA | TSAS | TFAS | |||||
TSSA | TFSA | Cp | Tini |
mat_ID | Material
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material
Initial
density (Real) |
E | Young's
modulus (Real) |
Poisson's
ratio (Real) |
E_mart | Martensite Young's
modulus (only available for solid element).
Default = E (Real) |
Material parameter
defining the start of phase transformation from austenite to
martensite (AS). 1 (Real) |
Material parameter
defining the end of phase transformation from austenite to
Material parameter
defining the start of phase transformation from martensite
to austenite (SA). 1 (Real) |
Material parameter
defining the end of phase transformation from martensite to
α | Material parameter
measuring the difference in response between tension and
compression. Default = 0 (Real) |
EpsL | Maximum residual
strain. 2 (Real) |
CAS | Stress-Temperature
rate during loading. Default = 0 (Real) |
CSA | Stress-Temperature
rate during unloading. Default = 0 (Real) |
TSAS | Initial temperature
for transformation (AS). Default = 0 (Real) |
TFAS | Final temperature
TSSA | Initial temperature
for transformation (SA). Default = 0 (Real) |
TFSA | Final temperature
Cp | Specific heat
capacity. Default = 1030 (Real) |
Tini | Initial
temperature. Default = 360 K (Real) |
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW71/1/1
metal
# RHO_I
6.50E-9
# E Nu E_mart
62500 .3 51000
# sig_sas sig_fas sig_ssa sig_fsa alpha
450 600 300 200 0.20
# EpsL CAS CSA TSAS TFAS
0.045 1 1 383 343
# TSSA TFSA CP TINI
363 403 837 360
#ENDDATA
/END
- The different stresses defining the start and the end of phase transformations, as well as the residual strain, correspond to the case of a uniaxial tensile test.
- The parameter α is computed from the initial value of the A → S phase transformation in
tension
and compression
from the relation:
(1)
Figure 1.List of Animation output (/ANIM/BRICK/USRI):- USR 1= Martensite phase fraction
- USR 2= Loading function
- USR 3= Unloading function
