/SKEW/MOV
Block Format Keyword Describes a moving local coordinate system.
| /SKEW/MOV/skew_ID | |||||||||
| skew_title | |||||||||
| node_ID1 | node_ID2 | node_ID3 | Dir | ||||||
| skew_ID | Skew identifier (Integer, maximum 10 digits) |
| skew_title | Skew title (Character, maximum 100 characters) |
| node_ID1 | Node identifier N1 (Integer) |
| node_ID2 | Node identifier N2 (Integer) |
| node_ID3 | Node identifier N3 (Integer) |
| Dir |
Default = X (Text) |
- Moving skew defines a local coordinate system, defined by three nodes. At each time, the actual orientation of the skew is recalculated according to the actual position of these nodes.
- For moving skews, the skew system is moving and is defined by node identifiers
node_ID1, node_ID2 and node_ID3.The axis definition depends on the input for Dir.
- When Dir=X
node_ID1 amd node_ID2 define
node_ID1 and node_ID3 define
Figure 1. Moving System with Dir=X - When Dir=Y
node_ID1 and node_ID2 define
Figure 2. Moving System with DIR=Y - Case Dir=Z
node_ID1 and node_ID3 defineThe skew is defined by , and
Figure 3. Moving System with DIR=Z
- When Dir=X
- When defining some conditions with respect to the skew in cylindrical coordinate system, the axis of the cylindrical coordinate system is assumed to pass through node N1.
