Transforms
Block Format Keyword Below are the transformation types and their description.
- It is recommended to use /TRANSFORM only with //SUBMODEL.
- This format can be used anywhere in the model.
- The transformations will be applied according to the order defined in the input deck.
- Several transformations may be applied on the same nodes group.
- The transformations are applied after the node group building.
- Transforms applied to node groups via grnd_ID only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed. To provide a complete transformation, the /TRANSFORM card should reference a //SUBMODEL and not a node group.
