/TRANSFORM/SYM
Block Format Keyword Defines a symmetry for a node group normal to the plane defined by a vector.
/TRANSFORM/SYM/transform_ID/unit_ID
transform_title
grnd_ID X_point_1 Y_point_1 Z_point_1 node_ID1 node_ID2
  X_point_2 Y_point_2 Z_point_2
transform_ID Transformation identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
transform_title Transformation title
grnd_ID Node group identifier. 2
(Integer)
X_point_1 X coordinate of point 1.
Default = 0.0 (Real)
Y_point_1 Y coordinate of point 1.
Z_point_1 Z coordinate of point 1.
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
X_point_2 X coordinate of point 2.
Y_point_2 Y coordinate of point 2.
Z_point_2 Z coordinate of point 2.
  1. If node_ID1 and node_ID2 are defined, the symmetry will be done on the plane normal to the vector defined by node_ID1 and node_ID2. The plane includes node_ID1. If only one node is defined, the error message is displayed.
    Otherwise, the symmetry will be done on the plane normal to the vector defined by point_1 and point_2. The plane includes the point_1.
  2. Transforms applied to node groups only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed.
