/TRANSFORM/TRA
Block Format Keyword Defines a translation for a node group with a defined vector.
/TRANSFORM/TRA/transform_ID/unit_ID
transform_title
grnd_ID X_translation Y_translation Z_translation node_ID1 node_ID2 sub_ID
transform_ID Transformation identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
transform_title Transformation title
grnd_ID Node group identifier. 5
(Integer)
X_translation Translation value along global X-axis.
Default = 0.0 (Real)
Y_translation Translation value along global Y-axis.
Z_translation Translation value along global Z-axis.
node_ID1 Node identifier 1.
(Integer)
node_ID2 Node identifier 2.
(Integer)
sub_ID Submodel identifier.
(Integer)
  1. If node_ID1 and node_ID2 are defined, the translation will be performed with the vector (node_ID1, node_ID2). If only one node is defined, an error message is displayed.
    Otherwise, the translation will be done with the defined value X_translation, Y_translation and Z_translation.
  2. A transformation can not apply to a node group and a submodel at the same time.
  3. If the transformation is done on a submodel, all the options of this submodel are transformed.
  4. A node can not be transformed both in a submodel and a node group.
  5. Transforms applied to node groups via grnd_ID only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed. To provide a complete transformation, the /TRANSFORM card should reference a //SUBMODEL and not a node group.
