/TRANSFORM/ROT
Block Format Keyword Defines a rotation for a node group around a defined axis, center of rotation and rotation angle.
| /TRANSFORM/ROT/transform_ID/unit_ID | |||||||||
| transform_title | |||||||||
| grnd_ID | X_point_1 | Y_point_1 | Z_point_1 | node_ID1 | node_ID2 | sub_ID | |||
| X_point_2 | Y_point_2 | Z_point_2 | Angle | ||||||
| transform_ID | Transformation
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| transform_title | Transformation
| grnd_ID | Node group identifier.
5 (Integer) |
| X_point_1 | X coordinate of point
1. Default = 0.0 (Real) |
| Y_point_1 | Y coordinate of point
| Z_point_1 | Z coordinate of point
| node_ID1 | Node identifier
1. (Integer) |
| node_ID2 | Node identifier
2. (Integer) |
| sub_ID | Submodel
identifier. (Integer) |
| X_point_2 | X coordinate of point
2. Default = 0.0 (Real) |
| Y_point_2 | Y coordinate of point
| Z_point_2 | Z coordinate of point
| Angle | Rotation angle value (in
degree's). Default = 0.0 (Real) |
- If node_ID1 and node_ID2 are defined, the rotation will be done around the vector defined by node_ID1 and node_ID2. The center of rotation will be the node_ID1. If only one node is defined, the error message is displayed.
Figure 1.Otherwise, the rotation will be done around the vector defined by point_1 and point_2. The center of rotation will be the point_1.
Figure 2. - A transformation can not apply to a node group and a submodel at the same time.
- If the transformation is done on a submodel, all the options of this submodel are transformed.
- A node cannot be transformed both in a submodel and a node group.
- Transforms applied to node groups via grnd_ID only transform the nodal coordinates. Material directions for orthotropic materials and boundary conditions such as initial velocity, imposed movement are not transformed. To provide a complete transformation, the /TRANSFORM card should reference a //SUBMODEL and not a node group.
