/NODE
Block Format Keyword Defines the coordinate of node, which is fundamental unit of graphic in structure.
/NODE/unit_ID | |||||||||
node_ID | Xc | Yc | Zc |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
node_ID | Node
identifier (Integer) |
Xc | X
coordinate (Real) |
Yc | Y
coordinate (Real) |
Zc | Z
coordinate (Real) |
- Nodes may be defined with more than one block.
