/RWALL
Block Format Keyword Defines the following types of rigid walls: Infinite Plane, Infinite Cylinder, Sphere and Parallelogram.
/RWALL/type/rwall_ID/unit_ID
rwall_title
node_ID Slide grnd_ID1 grnd_ID2
Dsearch fric ϕ ffac ifq
If node_ID = 0
XM YM ZM
If node_ID ≠ 0
Mass VX0 VY0 VZ0
If type is Plane, Cyl, Paral.
XM1 YM1 ZM1
If type is Paral.
XM2 YM2 ZM2
type Rigid wall type keyword
(see table below)
rwall_ID Rigid wall identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
rwall_title Rigid wall title
node_ID Node identifier (moving rigid wall)
(Integer)
Slide Sliding flag.
= 0
Sliding
= 1
Tied
= 2
Sliding with friction
(Integer)
grnd_ID1 Node group defining secondary nodes to be added to the rigid wall.
(Integer)
grnd_ID2 Node group defining secondary nodes to be deleted from the rigid wall.
(Integer)
Dsearch Distance for secondary search.
(Real)
[ m ]
fric Friction.
(Real)
ϕ Diameter of the sphere.
(Real)
[ m ]
ffac Filtering factor.
The default value depends on the ifq flag (Real)
ifq Filtering flag. 5
= 0 (Default)
No filter is used.
= 1
f f a c = α MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaiaadA gacaWGHbGaam4yaiabg2da9iabeg7aHbaa@3C40@ , a simple filtering value between 0 and 1.
= 2
ffac =N, the of time steps to apply the filter.
= 3
ffac=freq, cutoff filtering frequency.
Default = 0 (Integer)
XM X coordinate of M
(Real)
YM Y coordinate of M
(Real)
ZM Z coordinate of M
(Real)
Mass Mass of the rigid wall. 8
If no mass is entered, the rigid wall will have a constant imposed velocity.
(Real)
[ kg ]
VX0 Initial velocity in X direction
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VY0 Initial velocity in Y direction
(Real)
VZ0 Initial velocity in Z direction
(Real)
XM1 X coordinate of M1
(Real)
YM1 Y coordinate of M1
(Real)
ZM1 Z coordinate of M1
(Real)
XM2 X coordinate of M2
(Real)
YM2 Y coordinate of M2
(Real)
ZM2 Z coordinate of M2
(Real)
Rigid Wall Type
PLANE
∞ ¯ plane
CYL
∞ ¯ Cylinder of diameter ϕ
SPHER
Sphere of diameter ϕ
PARAL
Parallelogram
Surface Input Type
PLANE
MM1 defines the normal direction
rwall_lagmul_plane2
CYL
MM1 defines the axis of the cylinder
rwall_cyl
SPHER
M is the center of the sphere
rwall_spher
PARAL
M M 1 and M M 2 define the parallelogram
rwall_paral
  1. The first input defines the rigid wall coordinates of one point M or a node_ID in case of moving rigid wall.
  2. The next input is the coordinate of a point M1 and possibly a point M2 (in case of a moving wall, M1 and M2 have the same motion as node_ID).
  3. The secondary nodes to a rigid wall can be defined as a group of nodes and/or as nodes initially at a distance less than the distance (Dsearch) from the rigid wall.
  4. The friction filtering option is only available for a slide rigid wall with friction (Slide =2).
  5. Filtering flag ifg
    If ifq ≠ 0, the tangential (friction) forces in each secondary node in contact are filtered using a simple rule:
    (1)
    F T f = α F T ( t ) + ( 1 − α ) F T f ( t − d t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaGccqGH9aqpcqaHXoqycaWHgbWaaSba aSqaaiaadsfaaeqaaOGaaiikaiaadshacaGGPaGaey4kaSYaaeWaae aacaaIXaGaeyOeI0IaeqySdegacaGLOaGaayzkaaGaaCOramaaBaaa leaacaWGubGaamOzaaqabaGccaGGOaGaamiDaiabgkHiTiaadsgaca WG0bGaaiykaaaa@4D30@
    Where,
    F T f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaaaaa@38B5@
    Filtered tangential force.
    F T ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubaabeaakiaacIcacaWG0bGaaiykaaaa@3A26@
    Calculated tangential force at time t before filtering.
    F T f ( t − d t ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaCOramaaBa aaleaacaWGubGaamOzaaqabaGccaGGOaGaamiDaiabgkHiTiaadsga caWG0bGaaiykaaaa@3DE0@
    Filtered tangential force at the previous time step
    t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaads haaaa@37D8@
    Current simulation time
    d t MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiaads haaaa@37D8@
    Current simulation time step
    α MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3796@
    Filtering coefficient
    The flag ifq defines a method for filtering, α coefficient.
    If ifq =1, filtering coefficient is directly input by you: α = f f a c
    If ifq =2, α corresponds to a 3dB filtering level for user-defined frequency (frequency defined in terms of time step number):(2)
    α = 2 π N
    with 1 f r e q = T = N d t , and N = f f a c MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtaiabg2 da9iaadAgacaWGMbGaamyyaiaadogaaaa@3B73@
    If ifq =3, α corresponds to a 3dB filtering level for user-defined frequency:(3)
    α = 2 π d t ⋅ f r e q MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8WjY=viVeYth9vqqj=hEeuD0xXdbb a9frFf0=yqFf0dbba91qpepeI8k8fiI+fsY=rqaqpepae9pg0Firpe pesP0xe9Fve9Fve9qapdbaGaaiGadiWaamaaceGaaqaacaqbaaGcba GaeqySdeMaeyypa0JaaGOmaiabec8aWjaadsgacaWG0bGaeyyXICTa amOzaiaadkhacaWGLbGaamyCaaaa@46D6@
    Where,
    Time step
    f r e q MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaiaadk hacaWGLbGaamyCaaaa@39B8@
    ffac
  6. The sphere (SPHER) and parallelogram (PARAL) are not infinite. For parallelograms, the normal is defined using:(4)
    M M 1 × M M 2
    and the diameter of the sphere is defined using ϕ .
  7. Nodal thickness of rigid wall secondary nodes is not taken into account.
  8. For moving rigid walls with MASS=0 or blank, the rigid wall will have a constant imposed velocity and not an initial velocity.
