/RWALL/LAGMUL
Block Format Keyword Defines infinite plane rigid walls using the Lagrange multiplier method. This keyword is not available for SPMD computation.
/RWALL/LAGMUL/type/rwal_ID/unit_ID
rwal_title
node_ID Slide grnd_ID1 grnd_ID2
Dsearch
XM YM ZM
Mass VX0 VY0 VZ0
XM1 YM1 ZM1
Blank Format
type Rigid wall type keyword
(see table below)
rwal_ID Rigid wall identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
rwal_title Rigid wall title.
node_ID Node identifier (moving rigid wall).
(Integer)
Slide Sliding flag.
= 0
Sliding
= 1
Tied
(Integer)
grnd_ID1 Node group defining secondary nodes to be added to the rigid wall.
(Integer)
grnd_ID2 Node group defining secondary nodes to be deleted from the rigid wall.
(Integer)
Dsearch Distance for secondary search.
(Real)
[ m ]
XM X coordinate of M, if node_ID = 0.
(Real)
YM Y coordinate of M, if node_ID = 0.
(Real)
ZM Z coordinate of M, if node_ID = 0.
(Real)
Mass Mass of the rigid wall, if node_ID ≠ 0.
(Real)
[ kg ]
VX0 Initial velocity in X direction, if node_ID ≠ 0.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
VY0 Initial velocity in Y direction, if node_ID ≠ 0.
(Real)
VZ0 Initial velocity in Z direction, if node_ID ≠ 0.
(Real)
XM1 X coordinate of M1
(Real)
YM1 Y coordinate of M1
(Real)
ZM1 Z coordinate of M1
(Real)
Rigid Wall Type
PLANE
∞ ¯ plane
Surface Input Type
PLANE
MM1 defines the normal direction
rwall_lagmul_plane2
  1. The first input to define the rigid wall is the coordinates of one point M or a node_ID in case of moving rigid wall.
  2. The next input is the coordinate of a point M1 and possibly a point M2 (in the case of a moving wall, M1 and M2 have the same motion as node_ID).
  3. The secondary nodes can be defined as a list by nodes and/or as the nodes that are initially at a distance less than Dsearch from the wall.
  4. The defined nodes must have a non-zero mass.
