tria3
Unless otherwise specified, data names are accessible in level 3 only.
area
The element area.
Type: double
aspect
The element aspect ratio.
Type: double
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
centerx
The x coordinate of the element centroid.
Type: double
centery
The y coordinate of the element centroid.
Type: double
centerz
The z coordinate of the element centroid.
Type: double
collector
Pointer to the collector that owns the element.
Type: pointer (levels 2, 3 and 4)
config
The configuration of the entity.
103 - tria3
Type: unsigned integer.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
jacobian
The element jacobian.
Type: double
longestaltitude
The longest distance from a node to a non-adjoining edge.
Type: double
longestside
The longest element edge length.
Type: double
maxangle
The maximum interior angle.
Type: double
minangle
The minimum interior angle.
Type: double
node1 - node3
Pointers to the element nodes.
nodecount
The number of nodes for the element. Valid for hm_getvalue query only.
Type: integer
nodes
The list of nodes for the element. Valid for hm_getvalue query only.
Type: entity array
normalx
The x component of the element normal.
Type: double
normaly
The y component of the element normal.
Type: double
normalz
The z component of the element normal.
Type: double
property
Pointer to the property assigned to the entity.
Type: pointer
propertyid
The ID of the property assigned to the entity.
Type: integer
propertyidflag
1 if a property is assigned directly to the entity, 0 otherwise.
Type: integer
shortestaltitude
The shortest distance from a node to a non-adjoining edge.
Type: double
shortestside
The shortest element edge length.
Type: double
skew
The element skew angle.
Type: double
solverkeyword
The name of the solver keyword.
Type: string
type
The solver dependent type code for the entity.
Type: integer
typename
The solver dependent type name for the entity.
Type: string
warpage
The element warpage
Type: double
Version History
2020.1 - Added new data name solverkeyword.
