dobjrefs
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
configname
The solver name of the entity. Valid for hm_getvalue query only.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
loadsteplist
A pointer to the loadstep IDs (pointer value is loadstep ID)
loadsteplistmax
The number of loadstep IDs.
Type: integer
name
The name of the entity.
Type: string
negative_reference
Reference value for a negative response.
Type: double
negative_reference_toggle
On (1) and off (0) toggle for negative_reference. Valid for hm_getvalue query only.
Type: integer
objectid
ID of the objective function.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
positive_reference
Reference value for a positive response.
Type: double
positive_reference_toggle
On (1) and off (0) toggle for positive_reference. Valid for hm_getvalue query only.
Type: integer
reference
Reference flag. Valid values are:
0 - Negative response
1 - Positive response
2 - Both
Type: integer
responseid
The ID of the assigned response.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020.1 - Added new data name solverkeyword.
