configurations
Unless otherwise specified, data names are accessible in level 3 only.
activestate
Returns false if the entity is set inactive, true otherwise.
Type: Boolean
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
config
The configuration of the entity.
1 - Default
configuration_entities
The recursive list of children configuration entity IDs.
Type: integer array
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
part_entities
The recursive list of children Part Assembly and Part IDs.
Type: integer array
part_sets
The recursive list of children Part Set IDs.
Type: integer array
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020.1 - Added new data name solverkeyword.
