alereferencesystemswitches
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
101 - LS-DYNA *ALE_REFERENCE_SYSTEM_SWITCH
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id1
The first alereferencesystemgroup ID.
Type: entity
id2
The second alereferencesystemgroup ID.
Type: entity
id3
The third alereferencesystemgroup ID.
Type: entity
id4
The fourth alereferencesystemgroup ID.
Type: entity
id5
The fifth alereferencesystemgroup ID.
Type: entity
id6
The sixth alereferencesystemgroup ID.
Type: entity
id7
The seventh alereferencesystemgroup ID.
Type: entity
id8
The eighth alereferencesystemgroup ID.
Type: entity
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
t1
The first time for switching reference system type.
Type: double
t2
The second time for switching reference system type.
Type: double
t3
The third time for switching reference system type.
Type: double
t4
The fourth time for switching reference system type.
Type: double
t5
The fifth time for switching reference system type.
Type: double
t6
The sixth time for switching reference system type.
Type: double
t7
The seventh time for switching reference system type.
Type: double
type1
The first reference system type.
Type: integer
type2
The second reference system type.
Type: integer
type3
The third reference system type.
Type: integer
type4
The fourth reference system type.
Type: integer
type5
The fifth reference system type.
Type: integer
type6
The sixth reference system type.
Type: integer
type7
The seventh reference system type.
Type: integer
type8
The eighth reference system type.
Type: integer
Version History
2019
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
