curves
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
encrypted
True if the entity is encrypted, false otherwise
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
linetype
The line style used to draw the line.
Type: integer
markertype
The marker type used to indicate points on the curve.
Type: integer
name
The name of the entity.
Type: string
numberofpoints
The number of points in the curve.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
points
A pointer to the points in the curve (pointervalue is curve point).
scalex
The x scale factor.
Type: double
scaley
The y scale factor.
Type: double
solverkeyword
The name of the solver keyword.
Type: string
title
The title of the curve.
Type: string
width
The width of the curve.
Type: double
xcomp
The name of the x request component.
Type: string
xkind
The type of source for the x data.
0 - file
1 - math expression
xpath
The file path and name or math expression for x data.
Type: string
xreq
The name of the x request.
Type: string
xtype
The type of the x component.
Type: integer
ycomp
The name of the y request component.
Type: string
ykind
The type of source for the y data.
0 - file
1 - math expression
ypath
The file path and name or math expression for y data.
Type: string
yreq
The name of the y request.
Type: string
ytype
The type of the y component.
Type: integer
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
