freebodysections
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
0 - FBD load
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
elemidlist
The element ID list.
Type: entity array
entityids
The entity ID list.
Type: entity array
entitytype
The type of the entity.
2 - Elements
80 - Cross section
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
nodeidlist
The node ID list.
Type: entity array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
resolve
Resolve in the chosen system type:
0 - Analysis system
1 - Global system
2 - User system
Type: string
solverkeyword
The name of the solver keyword.
Type: string
system
The system ID when resolve is 2.
Type: entity
summationpoint
The symmation coordinates when summationpointtype is 2.
Type: triple double
summationpointtype
The symmation location:
0 - Centroid
1 - Node
2 - Position
Type: triple double
summationnode
The symmation node ID when summationpointtype is 1.
Type: entity
Version History
2019.1
2020 - Added new data names color_rgb and elemidlist.
2020.1 - Added new data name solverkeyword.
