panels
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
Entitylist
The elements contained in the panel.
Type: entity array
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
length
The length of the panel.
Type: double
name
The name of the entity.
Type: string
OuterElems
The outermost elements in the panel.
Type: entity array
OuterNodes
The outermost nodes in the panel.
Type: entity array
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
radius
The radius of the panel.
Type: double
solverkeyword
The name of the solver keyword.
Type: string
width
The width of the panel.
Type: double
Version History
2017.1
2020 - Added new data names color_rgb, length, radius and width.
2020.1 - Added new data name solverkeyword.
