encryptions
Unless otherwise specified, data names are accessible in level 3 only.
- activesuppressed
- Returns non-zero if the entity is set inactive, 0 otherwise.
- apa_license
- Option to define APA licensing for encryption.
- attributesmax
- The number of attributes owned by this entity.
- color
- The 1-64 color of the entity.
- color_rgb
- The RGB color of the entity.
- config
- The configuration of the entity.
- data
- The encryption key contents
- datamax
- The size of the data array.
- date
- The encryption time out date.
- definedentity
- True if the entity is defined, false otherwise.
- day
- The encryption time out day.
- feature_name
- The encryption feature to verify.
- FU_Option
- Differentiates the type of encryption key.
- hours
- The encryption time out hour.
- id
- The ID of the entity.
- include
- The ID of the include file the entity is organized in.
- includeid
- interface_id
- The internal ID which permits to encrypt options with a specific header.
- internalid
- KeydigitsRD
- The key digits for /KEY for Radioss from 1-99.
- keyid
- The key reference with format xxxxx, with any letter A-Z/a-z and digits 0-9.
- license_feature
- Option to define licensing for encryption.
- minutes
- The encryption time out minute.
- module_name
- The feature to check out for encryption.
- month
- The encryption time out month.
- name
- The name of the entity.
- outputsuppressed
- Returns non-zero if the entity is set "do not export", 0 otherwise.
- seconds
- The encryption time out second.
- solverkeyword
- The name of the solver keyword.
- time
- The encryption time out.
- time_out_Option
- Option to define time out for encryption.
- unit_costs
- The APA licensing cost for encryption.
- updateflag
- Flag to allow update on time out and licensing.
- year
- The encryption time out year.
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
2021 - Added new data names apa_license, date, day, feature_name, hours, interface_id, keyid, license_feature, minutes, module_time, month, seconds, time, time_out_Option, unit_costs, updateflag and year.
