pretensioners
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
config
The configuration of the entity.
101 - LS-DYNA *ELEMENT_SEATBELT_PRETENSIONER
curveid
The ID of the load curve for the pretensioner.
Type: entity
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
limitingforce
The optional limiting force for pretensioner types 5 or 8. If zero, this option is ignored.
Type: double
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
pretensioner_time
The time between the sensor triggering and the pretensioner acting.
Type: double
pretensionercpoint
The ID of the seatbelt control point.
Type: entity
pretensionerparent
The ID of the parent seatbelt.
Type: entity
sensorid1
The ID of sensor 1 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid2
The ID of sensor 2 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid3
The ID of sensor 3 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
sensorid4
The ID of sensor 4 of type *ELEMENT_SEATBELT_SENSOR.
Type: entity
solverkeyword
The name of the solver keyword.
Type: string
retractor_spring_id
The retractor number (SBPRTY = 1, 4, 5, 6, 7 or 8) or spring element number (SBPRTY = 2, 3 or 9).
Type: entity
type
The pretensioner type, ranging from 1-9.
Type: integer
Version History
2017.1
2020 - Added new data names pretensionercpoint and pretensionerparent.
2020.1 - Added new data name solverkeyword.
