comments
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
Type: integer
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
commentkeyword
Stores any LS-DYNA keywords prefixed with *COMMENT.
Type: string
commentlines
The comment text.
Type: string array
config
The configuration of the entity.
101 - *COMMENT
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
name
The name of the entity.
Type: string
numberoflines
The number of comment lines.
Type: integer
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
Version History
2020
2020.1 - Added new data name solverkeyword.
