ellipsoids
Unless otherwise specified, data names are accessible in level 3 only.
activesuppressed
Returns non-zero if the entity is set inactive, 0 otherwise.
attributesmax
The number of attributes owned by this entity.
Type: unsigned integer
center
The global coordinates of the center of gravity. Valid for hm_getvalue query only.
Type: triple double
centerx
The global x-coordinate of the center of gravity.
Type: double
centery
The global y-coordinate of the center of gravity.
Type: double
centerz
The global z-coordinate of the center of gravity.
Type: double
collector
Pointer to the multibody that owns the ellipsoid.
Type: pointer
(levels 2, 3, and 4)
color
The 1-64 color of the entity.
Type: integer
color_rgb
The RGB color of the entity.
Type: string
config
The configuration of the entity.
definedentity
True if the entity is defined, false otherwise.
Type: Boolean
id
The ID of the entity.
include
The ID of the include file the entity is organized in.
Type: entity
includeid
internalid
localcenterx
The local x-coordinate of the center of gravity.
Type: double
localcentery
The local y-coordinate of the center of gravity.
Type: double
localcenterz
The local z-coordinate of the center of gravity.
Type: double
multibodyid
The ID of the owning multibody.
Type: integer
name
The name of the entity.
Type: string
outputsuppressed
Returns non-zero if the entity is set "do not export", 0 otherwise.
Type: integer
radius
The principle radii. Valid for hm_getvalue query only.
Type: triple double
radiusa
The first principle radius of the ellipsoid.
Type: double
radiusb
The second principle radius of the ellipsoid.
Type: double
radiusc
The third principle radius of the ellipsoid.
Type: double
shape
shape The shape factor (N) for the ellipsoid.
Type: integer
solverkeyword
The name of the solver keyword.
Type: string
systemid
The ID of the system used to orient the ellipsoid.
type
The type of ellipsoid.
1 - ellipsoid
2 - cylinder
Type: integer
Version History
2020 - Added new data name color_rgb.
2020.1 - Added new data name solverkeyword.
